Code P2442 nightmare
Discussion in '2nd Gen Tundras (2007-2013)' started by Donbennyg, Jul 27, 2020.
  1. Jul 27, 2020 at 9:24 PM
    Donbennyg
    Donbennyg [OP] New Member
    2008 RED D-CAB
    I have a 2008 Tundra d-cab with a 4.7 v8 just got this dang code P2442. My question is this, how do i know what is damaged between the Air pump and the Secondary air injection check valve? i disconnected the hose that goes from the air pump to the check valve, disconnected the battery and i got no codes truck is working fine just idling a little lower. has anybody figured this out? dealer wants to replace air pumps and both secondary air injection check valves. charging me $3200 that i don't have. can anybody give me a hint please?
  2. Jul 27, 2020 at 9:32 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    I was under the impression that it was the electric solenoid or actuator that fails which makes the valve not function.
    There are bypass kits available to disable the air pump system. The truck can run without it but the computer needs to be tricked or made to think it is functioning.
    Google the aip bypass kit for Tundra, thinking a few hundred $$.
    Good Luck!
  3. Jul 27, 2020 at 9:33 PM
    Trooper2
    JR
  4. Jul 27, 2020 at 9:41 PM
    Donbennyg
    2008 RED D-CAB
    THANK YOU VERY MUCH I WILL LOOK INTO IT.
    Leo's first likes this.
  5. Jul 28, 2020 at 2:38 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    If you decide to go this route, I would go with their Gen 2 Bypass kit. It is a updated kit over their original. I installed it on my 08 and KNOCK! have not had anymore problems. Kit is plug n play for the most part.:thumbsup:
    https://hewitt-tech.com/store/
    Black Wolf, Trooper2 and ColoradoTJ like this.
  6. Jul 30, 2020 at 9:59 PM
    kanger328
    kanger328 New Member
    Anchorage, Alaska
    2012 DC 4x4
    I did the gen 2 kit as well. Worked like a charm. $400 is much better than the $2800 the dealer will quote you.
  7. Jul 31, 2020 at 5:28 AM
    Donbennyg
    2008 RED D-CAB
    I appreciate the advice, I went ahead and ordered the Gen II bypass Kit. I did buy both Air Injection Check Valves for $120 Each at Rockauto.com, I installed them myself yesterday. It was surprisingly very easy, a ratchet a long size 10 and 12mm a swivel and a long extension. It took longer to figure out what I was going to do. Cleared the codes and VUALA! Big red is running like a champ again. Thank you all for the bypass tip, it has been ordered.
    300BLK, Trooper2 and Black Wolf like this.
  8. Jul 31, 2020 at 10:09 AM
    Trooper2
    JR
    If install is really that easy or doable I wonder why dealer charges so much?
    Can you share the RockAuto parts ordered / installed?
  9. Jul 31, 2020 at 12:35 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Isn't there a way to redirect or add some kind of filter to the AIP inlet to prevent these problems in the first place? I admit I'm not entirely familiar with all the parts of the system.
  10. Jul 31, 2020 at 1:15 PM
    Donbennyg
    2008 RED D-CAB
    Sure! Part # 911622 ultra power $119.79 bank 1 (driver side) bank 2 (passenger side) are both the same. For those that want to change or having issues with a seizing air pump/smog pump the part number is Ultra power part#306010 for the motor base assembly only $85.79 or SKP PART# skap913060 $94.79 right and Ultra Power P# 332504M complete unit $102.79. I don’t know what the differences in the pumps are but the brackets are different. One is by the passenger side tire and the other is behind the intake. I can send pics of the check valves if needed.
  11. Jul 31, 2020 at 1:20 PM
    Donbennyg
    2008 RED D-CAB
    Apparently the only thing available is to bypass the system. I took apart the old check valve and all it is, are some flaps. In time due to opening and closing, they bend the opposite way and stay open.
  12. Jul 31, 2020 at 5:07 PM
    Donbennyg
    2008 RED D-CAB
  13. Jul 31, 2020 at 5:10 PM
    Donbennyg
    2008 RED D-CAB
    These are the air injection check valves top pic bank 2 (passenger side) bottom pic bank 1 (driver side)
  14. Jul 31, 2020 at 5:35 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    And the dealer wanted $3200 to replace those? What a bunch of thieves!
  15. Jul 31, 2020 at 5:46 PM
    rons23
    Ron
    Kill Devil Hills
    Hahaha, it's more involved than that. Your water pump gets replaced. Majority of cost is labor.
    bleach[QUOTED] likes this.
  16. Jul 31, 2020 at 5:47 PM
    Trooper2
    JR
    I thought the AIP valves were behind the engine. Always heard there was a lot of work to get to them. :notsure:
  17. Jul 31, 2020 at 5:49 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    I guess I don't know much about the system. The water pump is tucked under all the riming belt crap. That much I know when I changed my belt.
  18. Aug 1, 2020 at 5:06 AM
    rons23
    Ron
    Kill Devil Hills
    Yeah, it's labor intensive. What I'm Pissed off about is when they replaced the pumps @ 66k they were supposed to be a improved design. 60 k later having same issues until I installed Hewitt kit.
  19. Aug 1, 2020 at 6:26 AM
    Donbennyg
    2008 RED D-CAB
    In reality they wanted to switch out both air pumps and both check valves. They told me it has to be done that way.
    Check valves- $390 x 2 + tax = 844.35
    Air pumps - $465 w/bracket + $305 secondary + tax = 833.53
    Parts- $1677.88
    Labor- 20 hrs. @ $75 p/hr = $1500
    Total = $3177.88
  20. Aug 1, 2020 at 6:42 AM
    Trooper2
    JR
    So just new check valves was all you really needed? Curious what made you try replacing just the checks?
  21. Aug 1, 2020 at 8:40 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    I think mine has been worked on twice by the PO and I'm at 137K miles.
  22. Aug 1, 2020 at 10:16 AM
    Donbennyg
    2008 RED D-CAB
    ObdII scanner only gave P2442 twice bank one and bank 2 open. I didn’t get any P04— codes given for faulty Smog/Air pumps.
  23. Aug 6, 2020 at 9:25 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    I'm glad there's a less expensive fix from a company like Hewitt to provide a less expensive and possibly permanent fix. I can't imagine how many people that paid the dealer to have it "fixed" that had no knowledge of the the bypass.
  24. Nov 21, 2020 at 5:23 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    I ran across a TSB somewhere that explained that the whole system needs to be replaced even if the code is for a valve. Depending on model year and vehicle, some components are updated to prevent water intrusion. That’s why the dealer charges so much.... cause Toyota tells them to replace pumps and valves.
  25. Nov 27, 2020 at 1:40 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    That's a good reason to never take your out of warranty Toyota to the stealer for repairs. My elderly mom took her 06 Corolla to a local dealer for a check engine light. She didn't ask me for advice and unfortunately came out with her pocketbook $7000 lighter for a new transmission! :censored: dealer!
