Code P0415 Cant figure it out.
Discussion in '2nd Gen Tundras (2007-2013)' started by Rudy741, Jul 31, 2025.
  1. Jul 31, 2025 at 6:25 PM
    Rudy741
    Rudy741 [OP] New Member
    Rudy
    2012 Tundra 4.6L Gray
    I am new here and in need of some help. I have a 2012 Toyota Tundra with a 4.6L engine. Back in March, I replaced both Dorman OE Secondary Air Injection Valves: bank 1 and bank two. I replaced all four oxygen sensors upstream and downstream. Last weekend, I replaced both of the secondary air injection pumps as well as the catalytic converter on the driver's side. I still need to install the right side catalytic converter. Now I am still getting a P0415 code. What am I doing wrong?
  2. Jul 31, 2025 at 6:32 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
  3. Jul 31, 2025 at 6:44 PM
    Rudy741
    Rudy
    I'm finding that out the hard way lol. Thank you for the diagrams. I will try to make sense of it all.
  4. Jul 31, 2025 at 7:37 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Some codes are hard set and need a few cycles to clear once the failed part has been replaced. If you don't have tech stream it may not help but gives a decent idea of what plugs and wires to check on the air pumps and drivers. Driver plugs for pump 1 and 2 are located in front of master cylinder and fuse box.
  5. Aug 1, 2025 at 3:21 PM
    Rudy741
    Rudy
    I will look into it. I also came across today and will call the local dealership about it,
    Toyota has issued Technical Service Bulletins (TSBs) for 2012–2014 Tundras related to the air injection system and limp mode triggers. These updates involve ECM calibration changes to prevent false fault codes and improve drivability.
    If your truck has ever thrown P2440, P2441, P0418, or P0415, or entered limp mode unexpectedly, a reflash might be recommended—even if not required
