Code P0012 --- New Motor
Discussion in '2nd Gen Tundras (2007-2013)' started by bumpskir, Apr 15, 2019.
  1. Apr 15, 2019 at 5:38 AM
    bumpskir
    bumpskir [OP] New Member
    I have a 2012 Tundra Dbl cab with the 5.7 engine I purchased new from my local Toyota dealer, that now has 143K on it. They have done all the required maintenance and service recommendations over the years. In December my check engine light went on with code P0012 VVT01 bank 1 over Retarded. The dealer first replaced the Oil Control Value and tested. This cost $800. 3 Weeks later, the check engine light came on again with the same code, and they ended up replacing VVT-I Bank 1 and Bank 2. This was $2500. 3 weeks ago, the light came on again with the same code. This time they said they did all tests and worked with Toyota to get some ideas. They first said that it may be a stretched timing chain and did a bunch of tests, and found that it was not the problem. They then said it was the ECU and the cost for the part is $1600.00. I told them to do it, I just want my truck back after 2 weeks. They replace it last week and said that it is still giving the code and has low oil pressure. They said that someone from Toyota actually came to the shop to work with them and they concluded that I need replace the motor. Has anyone had anything like this happen with this code ? I purchased this truck expecting to have to do some maintenance and repairs, but not a new motor at 150K.
  2. Apr 15, 2019 at 5:52 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    You have paid them 5k and it is not fixed? I'd call Toyota USA and say you need tp good will whatever the fix is.
    Good luck.
  3. Apr 15, 2019 at 6:02 AM
    motod6
    motod6 New Member
    David
    2015 White TRD
    X2
  4. Apr 15, 2019 at 6:43 AM
    Wow. Almost 5k into this mess and now a different motor?
    <70k mile engine are going for ~3500.00, plus install will add another 1500.00.
    Sure hope the dealership is refunding money. They didn’t properly diagnose the problem, and threw parts at it, expensive
    ones at that.
    Black Wolf and Waterboy45661 like this.
  5. Apr 15, 2019 at 9:25 AM
    Dr_Al
    Dr_Al New Member
    Al
    Sounds like your dealer was shotgunning the problem. Shotgunning is when they replace a part hoping it'll fix the problem without actually proving they have correctly diagnosed the faulty part. I agree with the others that some sort of compensation is in order or I would file a complaint with your state against the dealership. Either they stand behind their work or not.
