Coachbuilder VS Toytec Shackles
Discussion in 'Suspension' started by Slp82, Jul 26, 2018.
  1. Jul 26, 2018 at 12:26 AM
    Slp82
    Slp82 [OP] New Member
    2005 Tundra RC 4.7 4x4; Toytec Boss 2.0 kit; SPC upper control arms; addicted offroad front bumper & 9k winch, Brute Force sliders & rear bumper, skid row skid plates, 285/75r16 Cooper AT3, Detroit trutrac in rear.
    2014 Tundra 4x4 5.7L DC; Bilstein 6112s @ 1.9"; 35x12.50 Nitto Ridge Grapplers on 20x9 wheels with +25 backspacing; DV8 front & rear bumpers, Engo 12k winch (SOLD) 2005 Tundra RC 4.7 4x4 w/3" spacer, addicted offroad tube winch bumper w/9k Engo, homemade sliders, skid row skid plate, 285/75r16 Cooper AT3, Detroit trutrac in rear.
    So Ive been researching both Toytec shackles and coachbuilder. It appears the differences are as follows:
    1. CB is aluminum, Toytec is steel.
    I imagine CB (coachbuilder) chose to use aluminum for rust prevention for you guys up north. That being said, the Toytec look to be zinc plated, which will also prevent rust.
    2. The CB shackles are thicker than the Toytecs.
    Generally aluminum is weaker than steel, so I assume CB made them thicker to compensate for the weaker material. Regardless, both CB and Toytec shackles are clearly more heavy duty than the stock shackles.
    3. Toytecs are adjustable from 1" to 1.5". CB is custom ordered to the size you want of lift and not adjustable.
    4. CB shackles come with poly bushings and a drive line spacer to correct angles. Toytec charges about a $20 upcharge for 1 bushing.
    This is were things get confusing. CB states "bushings" (as in plural). I don't know if this means there is 2 bushings per side, or just two bushings total (one for each side). Toytec clearly states its one bushing they give per side. Unfortunately they don't say if the bushing is a "poly bushing" or just a cheaper rubber bushing.
    I originally felt like the Toytecs were a much better deal, until you figure in that the bushings and driveline spacers would cost almost $50 more to buy separately on top of the Toytec shackles cost. At that point the price difference would only be about $50 difference between the CB and Toytec, with Toytec being the cheaper.
    The last advantage I've "heard" about Toytec over CB, is if you are trying to fit a 35" spare under the truck, the Toytec will allow it, while the CB won't.
    If I missed anything, feel free to correct me if I am wrong or left something out.
    I personally think you can't go wrong with either of these products, and the price difference is almost negligible. If I later decide to do shackles, this will be a tough decision.
    equin, Prostar 190, JoshuaA and 2 others like this.
  2. Jul 26, 2018 at 2:56 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    To answer your question on the CB bushings, yes it comes with 2 per side.
    Rica25 likes this.
  3. Jul 26, 2018 at 3:49 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    You have to replace the bushings with the CBs too so it mates up with leafs properly. Popping the stock ones out of the eyelet is a fucking bitch lol.
    I ran CB +2s and was able to fit a 35" under the bed. You'll have to cut the guards off regardless in order to fit that size tire
  4. Jul 26, 2018 at 4:54 AM
  5. Jul 26, 2018 at 5:22 AM
    If you want the Toytec bushings the extra pricing is for a pair. Very high quality.Had my Toytec shackles for a couple years now. Zero rust. Not using drive line spacer. No issues there. I like the fact they are adjustable. A great deal. The old bushings are a pain to remove. You can borrow a bushing removal tool from most auto parts stores. Makes it a lot easier. Ditto on calling ToyTec for pricing .
    4x4_Angel and Slp82[OP] like this.
  6. Jul 26, 2018 at 7:03 AM
    Slp82
    What "guard" are you referring to that you have to cut?
  7. Jul 26, 2018 at 7:17 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    There are two spare tire guides / gaurds under the bed of the truck. You'll have to cut those off if you wanna fit a bigger tire under there
  8. Jul 26, 2018 at 7:18 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I got bushings for both sides with my Toytec shackles, they’re poly if I remember correctly. I just changed leaves so we didn’t have to pull the stock bushings, we’d of had to burn em out with a torch if using the original leaves lol.
    Black Wolf likes this.
  9. Jul 26, 2018 at 7:18 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    The toytec shackles keep the stock bushings for the top of the shackle where it is mounted to the frame. The replacement bushings that they provide replace the rear leaf spring bushing on both leaf springs.
    The bushings from Toytec are supplied by Energy Suspension. They are poly bushings. Energy suspension is the worlds largest manufacturer of performance polyurethane automotive components. http://energysuspension.com/products.html
  10. Jul 26, 2018 at 7:24 AM
    Slp82
    Good to know! Thanks!
  11. Jul 26, 2018 at 7:28 AM
    Slp82
    That is exactly what I was most curious about. Nice to know they are poly as well. I know CB said in a post that one of the bushings from the Toyota factory is the "only poly bushing on the whole truck". I wonder if that is the upper bushing where Toytec chose to keep the factory bushing?
  12. Jul 26, 2018 at 7:45 AM
    csuviper
    Broomfield, CO
    Im pretty sure they are OEM poly. They are two piece that slide in from each side.
    Here is what is provided if you get the bushing option.
    equin, Dilsky, boostedtrdpro and 4 others like this.
  13. Jul 26, 2018 at 9:25 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Toytecs here, top setting, ride improvement after install.
    Stock spare clearance:
    equin, Rica25, 4x4_Angel and 2 others like this.
  14. Jul 26, 2018 at 1:15 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Do the toytec shackles offer the same amount of lift as CB?
    Rica25 likes this.
  15. Jul 26, 2018 at 1:23 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    i have not had toytec but i do have @Coachbuilder1 units and they are extremely beefy. very well built. not to mention great service. he answered my calls and texts on evenings, weekends etc. David is a stand up guy that is passionate about his products. i also have his steering kit which is fantastic quality as well. he helped me iron out rear leaf springs (ome drakar) as well. great resource!
  16. Jul 26, 2018 at 1:26 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    You can google this
    3 offerings:
    CB +1 0.625"
    CB +2 1.25"
    CB +3 1.75"
    1 offering:
    Toytec 1"- 1.5" depending on holes you use
    Y0TA PR0, Rica25, glass25 and 2 others like this.
  17. Jul 26, 2018 at 1:35 PM
    TheBeast The Beach
    if you plan on squeezing a big spare tire I would go toytec.
    also check MCM fab and Total Chaos shackles. I personally run the MCM fab and they are solid.
    joonbug and Black Wolf like this.
  18. Jul 26, 2018 at 4:13 PM
    Slp82
    Well I just ordered Nitto Ridge Grapplers in 35x12.50r20 so not sure if the counts as a "large tire" or not, but I would guess so. I won't have a 35" spare until I wear these tires out, then I will take the best looking tire and put it under my truck as a spare.
    csuviper and Black Wolf like this.
  19. Jul 26, 2018 at 5:02 PM
    Cfincke
    San Antonio
    When I bought toytec shackles the cost difference was much more than $50 otherwise I would have gone with Coachbuilders.
    Here are prices I just found from reputable online sites:
    The CB +3 with poly bushing and carrier bearing is $340
    The toytec shackles with poly bushing is $156, the CB carrier bearing drop kit is $14
    $340 - $170 = $170 cost difference
    equin, Rica25 and AKJ78 like this.
  20. Jul 26, 2018 at 5:04 PM
    If u get a flat, be sure to move tires around if necessary. Bigger ones on rear
    Consider CL
    Rica25, 831Tun and TheBeast like this.
  21. Jul 26, 2018 at 6:32 PM
    Slp82
    Please post the location of the Toytec shackles for sale for $156. On Toytecs website they are $225 shipped.
  22. Jul 26, 2018 at 6:35 PM
    Slp82
    Yeah I have heard you should put smaller on the front. Excuse my ignorance, what does "consider CL" mean?
  23. Jul 26, 2018 at 6:39 PM
    In 2wd, power is at the rear diff. So naturally, you want those tires the same size. If not, you’re probably risking the rear diff, gear teeth, etc.
    CL: Craigslist. You can probably pick up a used tire in that size.
  24. Jul 26, 2018 at 6:52 PM
    Slp82
    Yeah I figured the rear diff wouldnt like that.
    Thats a good idea on CL. In fact I have a buddy who works at NTB... Ill bet he could find a worn out (low tread) 35" that they are disposing of and maybe even get it free.
  25. Jul 26, 2018 at 6:53 PM
    Slp82
    Im honestly excited if I can pick up a Toytec shackles for $156 with poly bushings. I will be all over that.
    trayday likes this.
  26. Jul 26, 2018 at 7:07 PM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    I know anything is possible. But is it common for the stock shackles to get bent? Buying a stronger aftermarket shackle would prevent that?
  27. Jul 26, 2018 at 7:13 PM
    Cfincke
    San Antonio
    619Tundra and trayday like this.
  28. Jul 26, 2018 at 7:26 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    What do you all think about coachbuilder toytec combo? Cb up front, TT in back
  29. Jul 26, 2018 at 8:35 PM
    Most folks here are buying aftermarket shackles for strictly lift.
  30. Jul 26, 2018 at 9:08 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    equin likes this.
