*COMPLETED* Coachbuilder TRD Pro Kit Install
Discussion in '2.5 Gen Tundras (2014-2021)' started by jmevis, Feb 6, 2019.
  1. Feb 6, 2019 at 6:25 AM
    jmevis
    jmevis [OP] New Member
    Nashville TN
    2017 Tundra Trd Pro
    I was able to jump in on a group buy and snag a TRD Pro kit from CB. I am going to attempt to install all the parts my self. Last night I tackled the bumper shim kit. Took me about 3hrs figuring out as I went and trying to track down a deep socket 14mm from a neighbor.
    All in all it wasn't super difficult. I followed forum write ups for removing the grill and the bumper cowls. The hardest part was removing the actual metal bumper and the extensions. They were torqued down pretty good and rightly so. I didn't have an air ratchet so I had to use a breaker bar to remove the metal bumper and then the bumper extensions. Here are some pics!
    If you have questions feel free to ask! I am not a professional, just a weekend warrior who is decent at figuring things out. 57110984907__381C6791-B215-4177-92C9-3701EC35808E.jpg
    I will update as I complete more, looking to do the rear shackles this weekend.
    bulldog93, Y0TA PR0, D4x4TRD and 5 others like this.
  2. Feb 6, 2019 at 7:26 AM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    Yep! Its to help clear larger tires. After I install the full kit i'm going with 35s.
    Y0TA PR0, saybng and Voyagermike like this.
  3. Feb 6, 2019 at 8:33 AM
    Dilsky
    Dilsky Toyota Brand *****
    Shawn
    Edmonton, Alberta
    2014 Platinum Tundra Crewmax Black
    King Front Coil-overs Coachbuilder shims Toytec Rear shackles - Stock Rear Baja Designs Sport Fog Lights Rough Country 30" Lightbar 18" Method Roost Wheels (Bronze) 285/70/R18 Nitto Exo Grapplers Diamondback HD Cover
    Nice! I did not even know this was a thing! would have saved me a bit of heat gunning!
  4. Feb 6, 2019 at 8:43 AM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    The grass is greener... the whole time I was thinking dang this is a lot of work to move the bumper .5 inches.
    jewsNbrews likes this.
  5. Feb 9, 2019 at 12:45 PM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    Ok update! I’m on mobile so I am having problems posting pics. Last night I installed the +3 shakles and the bearing drop kit. Did it alone with help from my wife when lining up the new shackle with the leaf spring. I bent the parts in place and she slipped the bolt in. All in all went smooth took about 3/4 hrs alone. But I was figuring out as I went.
    After
    Pay attention to the instructions on inserting the new bearing. I did not and I wasted time fighting. More updates coming! You wouldn’t think that little of a lift is noticeable. But it is! The bearing drop kit was very straight forward.
    bulldog93 and jewsNbrews like this.
  6. Feb 9, 2019 at 12:58 PM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    This morning I did the front shims. It is 100% not a single person job. I had a buddy come over half way through and that way a HUGE help. I had to run out and buy an electric impact wrench from Lowe’s rated at 450ftlb and still had trouble with one bolt.
    After
    How we did it was removed the sway bar bolt. Then the strut bolt. And then the 2 bolts holding the rotor to the lower control arm. All of these are EXTREMELY tight and required the electic impact, even one of them the impact couldn’t get and we had to use a large cheater bar.
    After we removed all those bolts we unbolted the strut at the top. My buddy stepped on the LCA and pressed down enough for me to slip the bottom of the strut out of the LCA. I then manipulated the rotor and all of the remaining connections while he guided the strut out, we put the shim on. Then we put it all back together.
    Notes: the sway bar is a pain to deal with. It is easier to work on putting back together with the wheels on and the truck on the ground. Just make sure you get both side in the LCA pocket before you lower the truck.
    I broke one of the bump stop extensions in side the frame (?) so my passenger side currently only has 1 bump stop. The bolt sheared right of wasn’t even really that tight when it happened. I’ll have to drill it out and get a new one I guess. *** ALSO David from CB sent me a brand new bump stop with out me asking so I have to figure out how to drill the old one out.
    Here is the current stance!
    Truck rides great!
    Next is steering kit (I don’t have the right size wrench to break the jam nut right now)
    Then wheel spacers. And then 35s!
  7. Feb 9, 2019 at 1:05 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    You think that bumper extender would hit a Aries 3” bull bar?
  8. Feb 9, 2019 at 2:09 PM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    I’m not sure depends on how the bar mounts. It legit only pushes the bumper out .5 inches.
  9. Feb 15, 2019 at 7:04 PM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    OK guys Update time! Tonight I finished installing the CB Steering Kit and the BORA wheel spacers. These 2 things were the easiest of everything to install. If anyone is interested I could prob do a wright up on the steering kit. I used blue loctite on the spacers. And I have an appointment to get a front end alignment tomorrow morning and then a 9:30 am to get the tires. I am super excited! Also very proud to say I am still the only one who has worked on my truck. Except for this wheel alignment that is going to happen tomorrow, and tire rotations that I get done for free at tire discounters. Here are some pics!
    Side by side
    New!
  10. Feb 16, 2019 at 7:55 AM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
  11. Feb 16, 2019 at 8:08 AM
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    I usually don’t like the white letters showing on tires but that looks NICE with cement.
    jmevis[OP] likes this.
  12. Feb 16, 2019 at 8:11 AM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    I’m kinda really digging the retro look.
  13. Feb 16, 2019 at 8:15 AM
    Cemented
    Cemented Function over Form
    Manuel
    2017 Cement TRD Pro
    Looks great!
  14. Feb 16, 2019 at 8:18 AM
    Cemented
    Manuel
    2017 Cement TRD Pro
    One heads up if you plan to run a 35” spare under the bed. You need to have the bolts for the CB shackles facing outwards in order to fit the full size spare between the beefier shackles - if you have the nuts towards the outside and have removed or bent the spare tire guides should be able to fit it.
    pkeawe809, mdrabicki and jmevis[OP] like this.
  15. Jul 26, 2019 at 7:07 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Old thread but how did you get the diff drop to fit with the trd skid plate?
  16. Jul 27, 2019 at 4:56 AM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    Didn’t do a diff drop. Just driveline spacer which did not require removing the skid.
    But I’m here to answer any questions.
  17. Jan 20, 2020 at 1:46 PM
    Pomp_Cat115
    Pomp_Cat115 New Member
    Los Angeles, CA
    How has the CB steering kit held up?
    HulkSmurf14 likes this.
  18. Jan 21, 2020 at 5:54 AM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    No issues. Still going strong about 30K miles on them now.
    Pomp_Cat115[QUOTED] likes this.
  19. Jan 21, 2020 at 6:47 AM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    What kind of MPG’s are you seeing with your setup?
    Pomp_Cat115 likes this.
  20. Jan 21, 2020 at 7:06 AM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    13.5-14 MPG. My daily commute to work is 8 miles one way all city.
  21. Jan 21, 2020 at 7:11 AM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    Not bad at all. I’m not getting much better on my stock suspension with Cooper 33’s
    jmevis[QUOTED][OP] likes this.
  22. Jan 23, 2020 at 7:53 AM
    Pitbull410
    Pitbull410 New Member
    2020 TRDPro CM MGM, 2018 LC200 MGM
    Can you post some more pics of your truck? Got me wanting to do the same thing now
  23. Jan 23, 2020 at 3:42 PM
    sstoddard
    sstoddard New Member
    Shawn
    2019 Crewmax Sport
    Alarm/start (Compustar Ft7000,Rf2wl1b 2-way remotes and Drone Mobile) Tailgate inserts NSV Lightbar Tailgate actuator Blacked out decals
    Where did you get the bumper shims from again?
  24. Jan 23, 2020 at 3:57 PM
    ackthresher
    ackthresher New Member
    Jamie
    2017 cement crew max tundra pro
    Coach builder has them!
  25. Jan 23, 2020 at 4:00 PM
    ackthresher
    Jamie
    :thumbsup:I’m planning on the same lift!!!!looks great!
  26. Jan 23, 2020 at 6:11 PM
    Moco
    Moco New Member
    Marcos
    Boerne
    2019 Tundra TRD Pro, 2015 JKU Rubicon, 2016 HD 48
    Have the same setup sitting in my tool box just waiting to find time to install.
  27. Jan 24, 2020 at 6:47 AM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    Is there something specific you're looking for?
  28. Jan 24, 2020 at 6:54 AM
    soobahru
    soobahru New Member
    2015 tundra 5.7L double cab 6.5ft 2019 tundra 5.7L limited crewmax
    How is the steering kit before and after driving experience?
  29. Jan 24, 2020 at 7:02 AM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    TBH there wasn't that much of a difference. I think I remember it beeping a little smoother? However, CB says that it improves the turning radius by being able to push the heavy tires farther.
    I installed the steering kit before I put the 35s on, I do like how beefy they are.
  30. Apr 13, 2020 at 11:32 PM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    I ordered my kit from CB today. Spoke with David and he answered all of my questions and gave me install advice as I plan to do it myself. Intend to put 35's on the stock TRD Pro wheels so I purchased the BORA spacers as well. I appreciate the install experience info and pictures, hope mine goes as smooth as yours did.
