Coachbuilder tie rods with 18x10 with -24mm offset rims looking for pics
Discussion in '2nd Gen Tundras (2007-2013)' started by Forcefed, Apr 23, 2020.
  1. Apr 23, 2020 at 6:25 AM
    Forcefed
    Forcefed [OP] New Member
    2007 Tundra Limited
    6 inch lift, ADS suspension, Alcan custom rear springs, 46 gallon metal gas tank, Full Line-x body, Wheels with 35's, Smittybilt bumpers front and rear, 10k warn winch, custom rack.
    My current project has hit a snag in the road. I am currently rebuilding the front end of my Tundra that already has a 6 inch pro comp lift. I installed ADS suspension all around, SPC upper control arms, poly inserts and new ball joints on the lower control arm, new steel braided brake lines, z36 power stop rotor and brake pads, new steering rack with poly inserts, and new hubs. Ended up having a problem with my wheel not fitting with with the pro comp tie rods. So, I called David at Coachbuilders and talked to him. I ordered a set from him, but I know I need to change rims and I'm looking for pictures of anyone running a 18x10 with a -24mm offset. I want to see the stance and how much it clears the tie rod by. If any one is running this type of setup please let me know.
