Coachbuilder shims for driver side lean
Discussion in 'Suspension' started by Eaganite, Sep 8, 2021.
  1. Sep 8, 2021 at 6:51 AM
    Eaganite
    Eaganite [OP] New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    Looking for some thoughts and advice on the use of these. I have a stock 2020 Limited with the Off Road package, and has the .5" driver side lean. I have been thinking about buying three of the 1/4" Coachbuilder shims, one for the passenger side and two for the driver side. This apparently would level the front and also add .5" lift to the front.
    My questions are: 1 Any adverse effect to ride or handling? 2 Would it be necessary to extend the stock bump stops? 3 Any thoughts on how this would change the front alignment specifications?
    Thanks in advance,
    Gary
  2. Sep 8, 2021 at 7:13 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    stock trucks usually do not have the lean, toyota has the suspension set up to account for that on a stock truck.
    But, no issues adding the shims. a 1/4 shim will lift 2x the height of the shim, so 1/4 = half inch. Putting two on DS will lift that size one inch, then one on PS will gain half inch. Will be no problem with ride/handling or need to bump stop changes. Do need to get an alignment anytime you mess with the front suspension.
