CoachBuilder Shackles
Discussion in 'Suspension' started by pvn.beluga, Mar 15, 2021.
  1. Mar 15, 2021 at 3:30 PM
    pvn.beluga
    pvn.beluga [OP] New Member
    Phuc (Phooc)
    Connecticut
    Okay, I need some clarification for those of you who upgraded your shackles.
    1) Can you upgrade shackles on your stock suspension? or advised not to until you get upgraded front suspension?
    2) Do the rear suspension add any additional lift, or is that the job of upgraded blocks or shackles?
  2. Mar 15, 2021 at 3:33 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Yes, you can upgrade shackles with stock rear leafs and shocks as there are different lengths of shackle available. However, in all cases you will be increasing the rear height. Depending on the weight you carry in the bed that may or may not be an issue.
    Depending on the length of the shackles, you will get different levels of rear end lift.
  3. Mar 15, 2021 at 3:35 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    That would primarily just add more "rake" if you don't upgrade the front suspension (by means of still running stock suspension on all corners). I can see it being beneficial for towing purposes.
  4. Mar 15, 2021 at 3:38 PM
    The articulation will be better as well. The OEM bushings are splined.
    pvn.beluga[OP] and mountainpete like this.
  5. Mar 15, 2021 at 3:38 PM
    mountainpete
    Yes. If you have stock front suspension and increase the shackle length in the rear it will create more rake.
  6. Mar 15, 2021 at 3:43 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Sounds great! That'll clear things up. Thank you!
