Coachbuilder Shackles and a 35inch spare
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Mf32, Apr 13, 2021.
  1. Apr 13, 2021 at 10:03 PM
    Mf32
    Mf32 [OP] New Member
    2020 TRD Pro Super White
    Finally putting +3 coachbuilder shackles on my 2020 Pro this weekend.
    I’ve read through some threads and have seen a couple mixed answers. Does anyone have a definitive answer and run these with a 35 inch spare?
    My tires are technically 34.5x12.5x18.
  2. Apr 14, 2021 at 12:21 AM
    MoonRock2021
    MoonRock2021 New Member
    2021 TRD Pro Crewmax Lunar Rock 2021 4Runner Nightshade
    Call David @Coachbuilder1 and he will explain how. It can be done.
  3. Apr 14, 2021 at 12:50 AM
    VENOMTRDPRO
    VENOMTRDPRO New Member
    2020 WHITE TRD PRO
    I have a 35 inch spare on the stock spare wheel. With the +3 shackles and TRD exhaust it absolutely would not fit. I ended up having the exhaust dump after the mufflers. It’s a little tight but it now fits in the original spot.
  4. Apr 14, 2021 at 3:48 AM
    timsp8
    NY
    I read where someone aired the spare down and used ratchet straps around the tire to make it fit. You’d have to have an air compressor if you do this though. Not sure what damage if any it does to the tire, like permanent flat spots.
