Coachbuilder +3’s/TRD swaybar help
Discussion in 'Suspension' started by Zero One Actual, Jun 13, 2019.
  1. Jun 13, 2019 at 12:42 PM
    Zero One Actual
    Zero One Actual [OP] Member among Members
    I have the TRD swaybar and @Coachbuilder1 +3 shackles. We are installing them now and the sway bar is contacting the leafs after the addition of the +3 shackles.
    What am I doing wrong? I’m fairly sure others have run the sway bar and +3s.
    Will it correct once I add the tires and get it off the lift?
    @Coachbuilder1
    Thanks for any assistance everyone.
    Coachbuilder1 likes this.
  2. Jun 13, 2019 at 12:52 PM
    TuFerLife
    TuFerLife New Member
    Taylor
    Chattanooga, TN
    2018 Tundra TRD Sport 4x4
    3" Toytec Eibach coilovers with .5" coachbuilder shims and Coachbuilder +3 shackles, JBA Upper Control Arms, Fuel Assault 20x10 -18 offset on 35x12.50 Cooper ST Maxx, Amp research stepbars, JBA Long tube headers, custom mid pipes and TRD Replacement exhaust system by Dirty Deeds, TRD Black Chrome Tailpipes, Bullit liner spray in liner, S&B CAI, Katzkin leather with Degreez heated and cooling system, Husky floorliners, Coachbuilder roof rack with 13 Rigid pods and Switchpro switch, TRD skid plate, Pop-N-Lock, Auto Tailgate down mod, Rattletrap sound deadener in headliner and door panels. Kenwood DDX 9906XR headunit with full Tech 12 volts sound system and dash cam.
    I'm just here to follow this post... I have the Toytec shackles at 1.5" and they're not contacting my rear sway bar... But I've been looking at switching to coachbuilder +3's, so I'm here for the advice.
    Clean ass truck, BTW.
  3. Jun 13, 2019 at 12:54 PM
    Zero One Actual
    It’s clean because it only has 2000 miles on it. But this forum said I must mod or I’m a big loser. Soooooo...
    I’m 95 percent certain it’s the human that’s wrong here and not the hardware. This is my first go at this stuff and my friend is a professional mechanic. So we are thinking we did something wrong.
    TuFerLife[QUOTED] likes this.
  4. Jun 13, 2019 at 12:56 PM
    TuFerLife
    Taylor
    Chattanooga, TN
    This forum would be correct. :rofl:
    Also, I just went and looked at my toytec shackles and they're not anywhere near the sway bar... I know mine are only at 1.5", and the +3's are at 1.75".... But that does seem odd.
  5. Jun 13, 2019 at 12:58 PM
    Basskrazee
    Basskrazee Pop
    Joe
    Indianapolis, IN.
    2016 Tundra SR5 /TRD
    AFE mass air intake TRD rear anti sway bar Headwaters seat covers TRD Pro grill Bilstien 6112 coil overs Bilstien 5160 rear shocks Consol vault
    It will be fine. If got the same set up
    Zero One Actual[OP] likes this.
  6. Jun 13, 2019 at 12:59 PM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    I’d be willing to bet your paycheck that it’s because your suspension is fully unloaded
  7. Jun 13, 2019 at 1:00 PM
    Zero One Actual
    I’m thinking it’s something as stupid as once we lower it and the weight is applied to the tires, leafs and shackles that it will be fine. But I’m not the mechanic. So we are working on other stuff now until we figure it out. AKA a genius here tells me how to un$&!k myself.
  8. Jun 13, 2019 at 1:02 PM
    Zero One Actual
    So drop it like it’s hot?
  9. Jun 13, 2019 at 1:04 PM
    TuFerLife
    Taylor
    Chattanooga, TN
    :rofl::rofl::rofl:
  10. Jun 13, 2019 at 1:56 PM
    TuFerLife
    Taylor
    Chattanooga, TN
    You might want to read the coachbuilder group buy thread. People talking about having to flip the rear sway bar with +3’s.
  11. Jun 13, 2019 at 2:45 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Thanks for posting.. Once the rear suspension is fully assembled and the truck is back down on the ground you can then re connect the sway bar end links.
    ** With the +3"s installed we are still within range for the sway bar to function correctly :)
    Toyokuhl and Toyotoholic like this.
  12. Jun 13, 2019 at 3:10 PM
    Zero One Actual
    Thanks so much for the verification, peace of mind and actually calling me as well to verify everything.
    Best customer service ever @Coachbuilder1
    Toyokuhl likes this.
  13. Jun 13, 2019 at 3:16 PM
    That sway bar is installed wrong. Look at how your vertical bar is attached at the end link. Yours is installed on the inside which puts it against the leaf pack. Look how mine is installed on the outside. Notice the mounting configuration of the upper bolt to the frame as well. Looking at the pic again, the passenger side is correct. See page 4 for correct configuration.
  14. Jun 13, 2019 at 3:25 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Ya that arm that goes up Needs to go to the outside of the frame
    Amnesiac and Zero One Actual[OP] like this.
  15. Jun 13, 2019 at 4:51 PM
    Zero One Actual
    So don't drink beers while installing important stuff?
    Seriously though. Thanks for taking the time out of your day to help me fix mine. That's badass,
  16. Jun 13, 2019 at 5:24 PM
    Not a problem at all. I was aircraft maintenance and a jet engine mechanic on active duty for 24 years so I still have a good eye to catch something like that lol.
  17. Jun 13, 2019 at 6:02 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    87C6CC21-B30E-4AC2-B22A-4D57B1FB706B.jpg Sway installed like this will make it work. I’m at CB+3 as well.
  18. Jun 13, 2019 at 6:09 PM
    The issue with his was the end link on the drivers side was mounted wrong.
  19. Jun 13, 2019 at 6:11 PM
    Amnesiac
    Amnesiac When I am king, you will be first against the wall
    PDX
    2019 Superwhite TRD Sport
    Is that how it’s installed from the factory? Getting CB+3’s installed in a couple weeks and have the rear sway bar installed from the factory.
  20. Jun 13, 2019 at 6:13 PM
    No but some guys rotate the ubolt mounts that way for different reasons. The OP's end links should be on the outside. The pass side is correct but drivers was not.
  21. Jun 13, 2019 at 6:19 PM
    Amnesiac
    PDX
    I was actually asking about the picture @4Runner posted, but based on the comparisons of pics from him and OP it looks like his is rotated up? Guess I’m trying to figure out if I need to let my installer know about anything beforehand or not with a factory installed sway bar.
  22. Jun 13, 2019 at 6:27 PM
    4Runner
    4Runner New Member
    Columbia, SC
    I’m just posting that I have TRD RSB, TRD exhaust, and CB+3 and this is what was needed to clear springs and exhaust. Oh yea, muffler hangers needed as well. Regardless of the links. Hope this helps.
  23. Jun 14, 2019 at 12:27 PM
    Zero One Actual
    Did we graduate?
    No regerts.
    AZTundra likes this.
  24. Jun 14, 2019 at 12:48 PM
    Little more clearance around the leafs now? :thumbsup:
  25. Jun 14, 2019 at 1:59 PM
    Zero One Actual
    Almost done.
    4Runner likes this.
  26. Jun 14, 2019 at 2:20 PM
    AZTundra
    Paul
    Phoenix, AZ
    Everything squared away now?....I'll be adding the +3's here as soon as the group buy happens (also have the RSB installed).
  27. Jun 14, 2019 at 2:22 PM
    AZTundra
    Paul
    Phoenix, AZ
    We both have the Rear Sway Bar, TRD Exhaust and AMP Step :thumbsup:. But I don't have that nice Decked system on mine :(....
  28. Jun 14, 2019 at 2:46 PM
    Zero One Actual
    The @DECKEDUSA systems is phenomenal. I can’t recommend it enough. If you don’t have a very specific everyday need in your truck bed for the deep bed you should really look into it. It’s a buy once cry once thing. Pay the money. Instal it. And once you get all your stuff organized in it and still have some truck bed to use you will wonder why you didn’t do it sooner. It was the first thing I did to my truck.
    Thank you all again for the help and walk though while my truck was up on the lift. If you come through Charleston SC let me know.
  29. Jun 14, 2019 at 2:46 PM
    AZTundra
    Paul
    Phoenix, AZ
    Just noticed you also flipped the ubolts on the swar bar. Can you confirm if that was also required to clear?
  30. Jun 14, 2019 at 2:49 PM
    Zero One Actual
    @4Runner is the one who did it first and passed on that info here in this thread to me. I don’t know myself if it is “required” to clear but when multiple Toyota techs all go “that’s way better” then I digress to their knowledge.
    AZTundra[QUOTED] likes this.
