Coach Builder Tie Rods
Discussion in 'Suspension' started by cementsharktrd, Feb 28, 2022.
  1. Feb 28, 2022 at 10:34 AM
    cementsharktrd
    cementsharktrd [OP] New Member
    Demetrio
    2021 Cement Tundra TRD Off-Road
    7 inch bds coilover lift kit
    Got my coach builder tie rods arriving today. Any experience with installing these tie rods yourself? Really don't want to pay 400 dollars worth of labor for something I may be able to do on my own.
  2. Feb 28, 2022 at 10:48 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Installing tie rods is pretty basic for the most part. You would obviously need an alignment after.
  3. Feb 28, 2022 at 10:53 AM
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    '16 Super White CrewMax
    Very simple - I see you have the same BDS lift I do. You have to drill out the BDS spindle hole with the supplied drill bit so it is straight and not tapered for factory tie rod ends. Call David if needed, he is extremely helpful and responsive from my experience. Run a string line from the rear tire edge to the front tire edge if you want to attempt to get the toe close before taking it to an alignment shop and tell them not to touch the adjuster nut on the end links but adjust from the inner tie rod.
