Coach Builder 1" shims and Bilstein 6112's
Discussion in '2.5 Gen Tundras (2014-2021)' started by BoringAttitude, May 13, 2020.
  1. May 13, 2020 at 11:11 PM
    BoringAttitude
    BoringAttitude [OP] New Member
    2016 Tundra TRD Limited Crew Max
    K02 275/70/18 on ATX AX201, 6112's, Blah Bla
    Good evening all!
    New member here, but not new to the Toyota Family...
    Needed a better daily/work truck for a commuter and had to let my Superduty go (great truck by the way)
    I've got a 16' Limited TRD Offroad Crew Max. I've done a few mods to the truck but keep itching to do more. Debadged and Dechromed thanks to Sparks Parts. Added American Racing ATX AX201's (Wanted a factory-ish offset) and KO2's (275/70/16's) a while back.
    I didnt want to go the spacer route so went pretty mild with Coachbuilder 1" spacers for the front. I am looking for a little smoother ride and want to level the truck so have been eyeballing 6112's. I am only looking for 2 inches of lift to level the front.
    Question is, should I run the 6112's on a minimal setting in combination with the Coachbuilder shims or should I ditch them altogether and go with the 1.9" setting?
    I want to set it and forget it so coilovers are not really my jam. I ran OME in my old 4Runner and loved the kit but from what I have read they ride a little rough in the Tundra's and give almost 3"s of lift which is a little more than what I am looking for.
    Thanks in advance!
  2. May 14, 2020 at 12:02 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    If your looking for 2” I would just set at 1.9” and forget it. You can do shims but the only reason you would do that is to not preload you’re 6112 springs too much because of the stiff ride. Since you are essentially setting the 6112 at “middle” you won’t really get the stiff ride from preload like you would at 2.5”. I’m running 6112 at 1.9 and 1” of lift with shims for 2.9”. The 1.9 setting rides just fine so no real reason to fiddle fart with shims and subsequently bump stop extensions, which you will need of you run shims.
    glowblue likes this.
  3. May 14, 2020 at 12:07 AM
    Tundyfundy
    Bay Area, CA
    Now theoretically you get a smoother ride the less you preload the 6112 springs but I think you will see a dramatic improvement in ride from the 1.9 setting. I don’t think you’ll be able to tell much difference between the 1.3” setting. But if you did go with the 1.3 setting you would either run a half inch more lift with shims for 1.8” or one inch of shim lift for 2.3”. Remember that a one inch shim will give you two inches of lift. A half inch shim will give you 1” of lift and a 1/4” shim will give you .5” of extra lift.
  4. May 14, 2020 at 12:09 AM
    Tundyfundy
    Bay Area, CA
    6112 is set it and forget it. To re adjust you would have to completely un-install from truck which would be asinine. There is no easy adjustment on 6112 so it’s essentially a one time jobber unless you have a lot of time and money to waste.
  5. May 14, 2020 at 10:20 PM
    Kenny1794
    Kenny1794 New Member
    I'm running 6112/ front drive 1.9, passenger 1.3.... rear 5160. Truck is leveled. Went with a lil preload on driver to compensate for extra weight on drivers side of truck.
  6. May 15, 2020 at 3:18 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Ive read setting the 6112s driver and passenger side differently is not recommended so I set my 6112s to 1.9” and installed 2 shims in driver side and 1 shim on passenger. Added a Toytec shackle in rear to maintain a slight 1” rake which I’m glad I did because I hauled about 600 lbs of landscape stone yesterday!
  7. May 15, 2020 at 3:53 AM
    Tundyfundy
    Bay Area, CA
    Ditto. Different preload on each side not recommended.
