Coach builder +1 Shakles
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by Elduder, May 7, 2022.
Thread Status:
Not open for further replies.
  1. May 7, 2022 at 8:53 AM
    Elduder
    Elduder [OP] New Member
    Sold
  2. May 7, 2022 at 5:09 PM
    mattyd170
    mattyd170 New Member
    Albuquerque, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    TRD Front Suspension, Bilstein Rear, TRD rear sway bar kit, 35" tires, working on stereo.
    I'm looking at them. Might be interested. Let me so a little looking and research. Thanks.
    Elduder[OP] likes this.
  3. May 7, 2022 at 6:48 PM
    Elduder
    If you have any questions feel free to ask or look here:https://www.tundras.com/threads/the-coachbuilder-trd-pro.23416/
    I've ran the +3s and +2s, so I can also steer you in the right direction regarding height, even if it means not getting these ones. :hattip:
    GNTundra likes this.
  4. May 7, 2022 at 8:10 PM
    mattyd170
    Albuquerque, NM
    Thanks my friend. So I have a 2020 limited with a nice Leer shell, so back has a little weight on it. I have Bilstein 5160's in the rear and just bought TRD PRO Bilstein front coils with CB shims, 2 for driver and 1 for passenger. Worried front might be a little high. I just want it level. Thanks.
  5. May 7, 2022 at 8:53 PM
    pvmike
    pvmike Home Depot flexing
    Los Angeles
    2014 Platinum Super White
    TRD Pro suspension, supercharger, 5.29 gears, Auburn LSD
    I have TRD Pro Bilsteins front and rear, and then added CB +1 shackles for a little bit of rake. They only add 5/8 inch, and that was perfect for me. I'll bet it will be level for you with your Leer.
  6. May 8, 2022 at 6:05 AM
    Elduder
    Stock rear on these trucks seems to be around 2.5" higher than the front, sounds like you're adding 2.5" of lift to the front. With a camper the +1s would put you pretty close to exactly level. If that was your target and you ever needed more you could get a small leaf shim to fine tune it.
    Otherwise, the +2s would be a safe bet to prevent the front from ever looking higher than the rear, but they will almost certainly result is a small amount of visible rake.
    Im currently on +2s, front set to 2.75" of lift, the rear is still visibly higher.
  7. May 8, 2022 at 10:50 AM
    shawn3210
    shawn3210 New Member
    Southern California
    Had a question, I’m ordering king 2.5 front and rear with Camburg uca and shims would this be a good for the rear?
  8. May 8, 2022 at 11:08 AM
    Elduder
    Yes, unless you jacked the front up over 3” or carries weight in the rear constantly.
    The +1s are made to raise the rear enough on a 2.5” lift to be close to level. Lots of Pro guys add them to get some rake back. Basically with 2.5 in the front and +1s in the back you’ll be at .5” higher in the rear, maybe a tiny bit more.
  9. May 17, 2022 at 2:19 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    I think this is what I’m looking for… I’m adding 5100’s and was planning on running either the middle or top and I’ll need to raise the rear to level out. Not sure if I need the 1” or 2” shackle…
    also do these come with the bushings?
  10. May 17, 2022 at 8:30 AM
    Elduder
    These include everything necessary for install.
    Bushings
    Grease
    Bolts and shackles
    5100s and the +1s would work well with either the top or middle settings.
  11. Jun 5, 2022 at 8:46 AM
    Elduder
    For sale again, decided not to run them for now. My loss is your gain, price is about $40 less than new.
  12. Jun 27, 2022 at 9:00 AM
    Elduder
  13. Jul 6, 2022 at 9:37 AM
    Elduder
  14. Jul 6, 2022 at 11:40 AM
    heavyjay425
    heavyjay425 New Member
    Jayson
    2018 White Tundra 1794
    Still got them? What's the cost?
  15. Jul 6, 2022 at 11:57 AM
    Elduder
    $285 shipped
  16. Jul 6, 2022 at 2:49 PM
    heavyjay425
    Jayson
    Were they ever installed?
  17. Jul 6, 2022 at 4:44 PM
    Elduder
    They’re brand new
  18. Jul 8, 2022 at 4:26 PM
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    Does this come with the carrier drop bearing kit too ?
  19. Jul 8, 2022 at 7:03 PM
    Elduder
    I cant recall. I can open the wrapping up, if I remember correctly the +2s and +3s come with them. The +1s dont need them.
  20. Jul 8, 2022 at 7:38 PM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    12” Bulletproof Lift, AFE CAI, AFE Exhaust, rock lights, Fas-Top tonneau and soft topper, Dasaita 10.2” radio, light bar, ditch lights, LED headlights and fog lights, LED interior lights, Amp Research rear bumper step, dashcam, BT ODBII reader and Torque app on radio
    I’ve got a 2013 with the 12” Bulletproof lift. I’ve noticed it has a slight squat in the back and looking at these it looks like Coachbuilders makes kits for these lifts and the shackles help bring the rear more level.
    I just got the tie rod ends, so this would basically complete their kit.
    would these 1” do anything or should I look at the 3”?
  21. Jul 10, 2022 at 10:05 PM
    Elduder
    If the front is higher by anything less than 1/2" than the +1s will work. Otherwise I'd look into +2s.
    bulldog93 likes this.
  22. Jul 19, 2022 at 8:45 AM
    Elduder
    I’ll post updated pictures today.
  23. Jul 19, 2022 at 9:42 AM
    BoysandHisToys
    Central Virginia
    I ended up buying the 3”. Looks like Coachbuilders offers a full Bulletproof 12” lift “kit” which includes these 3” shackles for a more level ride.
    getting installed in two weeks.
  24. Jul 20, 2022 at 8:27 AM
    Elduder
    Added pictures without the wrap.
  25. Jul 25, 2022 at 11:18 AM
    Elduder
  26. Jul 25, 2022 at 11:32 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    How are these still for sale? I have these in my truck and it's fantastic. Adds back a little bit of rake if you are leveled. Perfect for towing.
    Elduder[OP] and French Avocado like this.
  27. Jul 25, 2022 at 12:55 PM
    Elduder
    :confused:
    Dunno, have had a ton of odd offers, most are forgetting that CB does charge shipping, so theyre pretty low.
    These are brand new and 15% off the cost of new from CB.
    memario1214 likes this.
  28. Jul 25, 2022 at 1:17 PM
    mountainpete
    Keep in mind that it’s $305 - 5% with the site promo code ($289.75). Your asking is still less and tax/shipping free.
    Elduder[QUOTED][OP] likes this.
  29. Jul 26, 2022 at 6:43 AM
    TH1776
    TH1776 New Member
    FL
    040 PRO
    I kinda want them, but I don't NEED them.
    Any interest in trading for a Pedal commander?
  30. Jul 26, 2022 at 6:54 AM
    Elduder
    I would, but already have a pedal commander. :thumbsup:
    TH1776[QUOTED] likes this.
Thread Status:
