CM rear doors won’t open from the inside
Discussion in '2.5 Gen Tundras (2014-2021)' started by graves037, Oct 11, 2018.
  1. Oct 11, 2018 at 8:54 PM
    graves037
    graves037 [OP] New Member
    Michael
    Pea Ridge AR
    16 Tundra SR5
    3" readylift, trail grapplers on 20" rockstar II's, truxedo lopro, lund bull bar, 20 & 30 in lightbars, tint, LEDs
    I’ve flipped the child lock thing up and down, flipped the lock back and forth, wiggled the handle.....neither of my rear doors are opening from the inside!! What should I check? I did recently have the panels off installing some speakers, which seems to be when it started. Everything is normal from the outside. Thoughts???
  2. Oct 11, 2018 at 9:24 PM
    Sounds like a mechanism wasn’t placed back. You’ll want to remove the panels again and try to see where it latches at
    TheBeast likes this.
  3. Oct 11, 2018 at 9:28 PM
    graves037
    Michael
    Pea Ridge AR
    16 Tundra SR5
    On the handle end or something inside the door?
  4. Oct 11, 2018 at 9:35 PM
    Since it’s ocurring from the inside, I would take the panel off and move the door latch from inside to see what it’s not connecting
    Black Wolf, 15whtrd and graves037[OP] like this.
  5. Oct 11, 2018 at 9:45 PM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    it's been a year since I was in there but I'm sure there was two cables I unhooked to get the door panel off, one for the latch and one for the lock. Probably never hooked them back up
  6. Oct 12, 2018 at 5:37 AM
    graves037
    Michael
    Pea Ridge AR
    16 Tundra SR5
    I remember hooking them back up, and the door has been opened since I removed the door panel.....guess maybe one popped out or something. I’ll tear into it this weekend and find out
  7. Oct 12, 2018 at 5:41 AM
    It's strange that both rear doors won't open. If you forgot to reconnect something on one door I'm thinking the other door wouldn't be affected.
  8. Oct 12, 2018 at 6:31 AM
    TomyTun
    TomyTun New Member
    CA
    2016 TRD Off Road, Crewmax, 5.7L Non-FFV
    None
    Same thing happened to my dad’s ‘14 double cab. He took his to the dealer to be fixed under warranty.
  9. Oct 13, 2018 at 10:13 PM
    Cavscout
    Cavscout New Member
    Rick
    2015 DC SR5 TRD
    Stock (mostly)
    Is there a child safety switch for the rear doors like I have seen on some other vehicles?
    15whtrd and TheBeast like this.
  10. Oct 13, 2018 at 10:23 PM
    TheBeast The Beach
    cables have a notch where you need to press them in. maybe it wasn't put back correctly and made its way out. it's mechanical so not much can go wrong here.
  11. Oct 13, 2018 at 10:31 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    child lock?
  12. Oct 13, 2018 at 10:38 PM
    Just a thought, do you have a aftermarket alarm? I had one installed and only driver side and passenger side would lock/unlock took to another installer, they said who installed wired wrong, now all doors lock/unlock
  13. Oct 14, 2018 at 7:12 AM
    graves037
    Michael
    Pea Ridge AR
    16 Tundra SR5
    The cable just popped back out of it’s slot apparently.....thanks for the input guys!
    15whtrd likes this.
  14. Oct 14, 2018 at 4:20 PM
    Wisconsin Tundra
    Wisconsin Tundra New Member
    Patrick
    Wisconsin
    2013 Tundra crewmax
    Make sure your cables are locked into place on inside of panel.
    graves037[OP] and TheBeast like this.
