Cluster and Dash Led type help
Discussion in '1st Gen Tundras (2000-2006)' started by Myrtille2004, Nov 14, 2018.
  1. Nov 14, 2018 at 9:20 AM
    Myrtille2004
    Myrtille2004 [OP] New Member
    Stephane
    Quebec, Canada
    Tundra 2006 SR5 Double Cab 2X4
    Stock. Next step Bilstein 5100.
    Hi. I saw many threads on clusters and Dash LEDs, but I am still loss on what I should order on Amazon. I have a 2006 double cab. I will like to know the led type and quantities I will need to:
    - Get blue led for cluster background + transmission lights
    - Control panel led type for AC control, fan and temp background, defrost, cargo, .... I think I may need 2 per switch (one to light up at night and one that said switch is on)
    Since LED evolve quickly, I will appreciate recent recommendation.
    Thabks
  2. Nov 14, 2018 at 2:10 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Check out superbrightleds.com
    They should have the sizes listed. Heads up the sizes they list for the dome and map lights is wrong, just FYI. I know from experience. The dash lights should be 194 I believe. Iirc it takes 4. The AC is either 74 or or a special type of bulb that I can't recall what it's called. But you need 3 of them I think. Here's a link with more info
    https://www.tundras.com/threads/climate-control-lighting.16678/
  3. Nov 18, 2018 at 5:36 AM
    Swalters
    Swalters Run your truck, not your mouth
    Sam
    Arizona
    "Attaque" - LT V8 4runner
    You need 4-194s and 1-74 for the dash lights You need a neo4 4mm for each transmission light (so 6 total). I just ordered mine from super bright leds which is where I get all my bulbs.
    NewImprovedRon likes this.
  4. Nov 18, 2018 at 6:14 PM
    Myrtille2004
    Stephane
    Quebec, Canada
    I did replaced all my AC Controls bulb with LED. What a difference! For the Dash clusters, I got a surprise. See attached image. The board has integrated welded led in it, so no way I can change the bulb! Seems the 2006 model year do not have the good old bulb I can change. I will need to live with the low light green type...
  5. Nov 18, 2018 at 6:19 PM
    Casper421
    In the woods
    06 DC
    No you don’t...
    Outbound and bmf4069 like this.
  6. Nov 18, 2018 at 7:11 PM
    Swalters
    Sam
    Arizona
    I was getting ready to tag you! Sand that green shit off haha
    Casper421[QUOTED] likes this.
  7. Nov 18, 2018 at 7:13 PM
    Myrtille2004
    Stephane
    Quebec, Canada
    Will do. Just found info on the net how to do it. Thanks
    Swalters[QUOTED] likes this.
  8. Nov 20, 2018 at 11:13 AM
    TUNDRAIN520
    TUNDRAIN520 TUNDRAin520
    Travis
    Tucson, AZ
    2001 Extended Cab 4x4 SR5
    I might be thread jumping here, but... I have no illumination behind the A/C control knobs. I see above that there are 3 bulbs... I have 2 questions...
    1) Would it be odd for all 3 bulbs to be out? That seems improbable...
    2) How do I get to those bulbs?
    Thank you in advance...
  9. Nov 20, 2018 at 3:23 PM
    Professional Hand Model
    Hand Protectors
    Never done this before, but going on memory from watching a video there are three screws that hold that panel on. Two of which are behind two of the control knobs. Check out a youtube vid in first gen Tundra panel removal. Thats where I saw it. Seems pretty easy to access.
    TUNDRAIN520[QUOTED] likes this.
  10. Nov 20, 2018 at 3:33 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    At 17 years old, no it wouldn't be odd all 3 are out. PHM had part of it right, remove the 3 control knobs and remove the phillips head screws, push the vents on each side of the radio up and you'll see 2 more screws in there. Then grab the panel between the vents and radio and pull and the whole unit will come out.
  11. Nov 20, 2018 at 3:35 PM
    Hand Protectors
    Let us know what size bulbs those are.
    TUNDRAIN520 likes this.
  12. Nov 20, 2018 at 3:43 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    They're 168's
  13. Nov 20, 2018 at 4:35 PM
    Myrtille2004
    Stephane
    Quebec, Canada
    I just did my AC Panel. For the bulb, I used LED T10 to replace the 168. I will say night vs day for the lighting. Next project is the dash, the greenish make me sick ;)
  14. Nov 20, 2018 at 5:08 PM
    Hand Protectors
    I’ll try this T10. Hope no LED rejection. Just check my lighting and think my temp knob is out and sharing the light from the fan and function knobs. Wonder if the 4hi/lo and recirc bulbs are the same? Will do all simultaneously.
  15. Nov 20, 2018 at 5:37 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    IIRC those guys are LEDs in the switches themselves. On the other bulbs be sure to get something that throws a 360° beam or the backlight won't look right.
  16. Nov 20, 2018 at 6:01 PM
    Hand Protectors
    Do you have a picture of the new bulbs package? With part number and brand?
  17. Nov 24, 2018 at 5:15 AM
    Myrtille2004
    Stephane
    Quebec, Canada
    For the T10 i used these
  18. Nov 24, 2018 at 5:19 AM
    Myrtille2004
    Stephane
    Quebec, Canada
  19. Dec 18, 2019 at 10:54 PM
    2000Strong
    2000Strong Just a dude and his truck
    Benjamin
    Washington
    2000 Maroon Tundra, AC, Premium Audio, SR5 4.7
    All LED Interior lights, New Headlights, Break Controler, LineX Bedliner.
    Does anyone know what the led replacement for this bulb would be I was told it was a t4 neowedge but, the look different no grab and twist in tab.
  20. Dec 19, 2019 at 4:04 AM
    Hand Protectors
    The Partshams lights I used on cig light and ashtray will fit. The come with a new base(s) in a separate bag as a kit with the bulbs.
    The bulb is shaped differently so certain applications may throw differing light than a round bulb. Only place I‘ve had to adapt the positioning (as well as the body) was at the cig light.
    2000Strong likes this.
