Clunk/thud when turning before and after replacing everything!
Discussion in '1st Gen Tundras (2000-2006)' started by inv3ctiv3, Dec 25, 2024.
  1. Dec 25, 2024 at 10:16 PM
    inv3ctiv3
    inv3ctiv3 [OP] New Member
    Jim Bob
    So my truck (2006 AC 4.8 4x4) has this distinct clunk/thud that you can almost feel in the floor board when turning. I was convinced it was the steering rack bushings because they were shot but I just replaced them with poly bushings during my entire front end refresh.
    I just did:
    TC Lowers
    TC Upper
    TC Ball joint conversion
    TC Poly steering rack bushings
    TC Diff Drop (done months ago)
    ADS Coils
    DuroBumps
    Removed sway bar to rule out that or endlinks
    None of this fixed it, what am I missing that could be causing this? Front diff mount? Body bushings? Trans mount?
  2. Dec 25, 2024 at 10:30 PM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Those are possibilities. Body mounts being the lowest-possible cause. Is it possible for you to get the truck up in the air so none of it is "loaded" to see if you can replicate the clunk while turning? This would rule certain components out quickly.
  3. Dec 25, 2024 at 10:34 PM
    inv3ctiv3
    Jim Bob
    Tried that but it sounds like it only happens when under load.
    Desert Dog[QUOTED] likes this.
  4. Dec 25, 2024 at 10:42 PM
    Desert Dog
    Understood. Good call. I would look at mounts, related bolts and driveline components then. It's not your front-end components. Simple logic. Keep us posted, please.
  5. Dec 25, 2024 at 10:52 PM
    Desert Dog
    Just out of curiosity, is your truck lifted? If so, how much? It's possible your shocks aren't the correct length and are topping-out.
  6. Dec 26, 2024 at 3:37 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Weight reduction, mostly rust.
    As weird as this may sound, check your leaf springs to see if the wear pads at the tips of each end of the leafs are still there or worn down to nothing. It's pretty deceiving, and for me at least, it sounded and felt like it was front end or under my seat. Good luck! Report back when you track it down :thumbsup:
    The Black Mamba likes this.
  7. Dec 26, 2024 at 4:11 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    My rear leaf hangers were rusted to shit (huge blisters of rust) and made a loud clunk when I went over bumps or changed direction hard. It would resonate down the chassis such that I thought it was a front end problem.
    The Black Mamba and BroHon like this.
  8. Dec 26, 2024 at 8:24 AM
    inv3ctiv3
    Jim Bob
    It is lifted slightly but ADS got me setup I don’t think it’s that.
    They’re brand new archive garage springs
    Hmm my truck is a California truck I haven’t found any rust like that but I’ll double check back there.
  9. Dec 26, 2024 at 9:02 AM
    shifty` I'm having daydreams about night things
    Stupid question, does it happen when moving only, not when stationary?
    Another stupid question: Have you checked for rub marks? My tires smack the mudflaps up front at the pinch weld and make a thud while turning, any time I'm rolling in reverse. It won't happen if I'm turning in forward motion, or I'm turning stationary. It also happens when I'm turning and in compression at the same time. It's not like I'm running huuuge tires, 275/70r17 and this is happening.
  10. Dec 26, 2024 at 10:01 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Drive shaft carrier bearing min would clunck before I fixed it
    Desert Dog likes this.
  11. Dec 26, 2024 at 12:41 PM
    Desert Dog
    Worn driveline component somewhere is where I'd be focusing based on OP's descriptions.
  12. Dec 27, 2024 at 5:27 PM
    Rich L.
    Rich L. This too shall pass
    Pacific NW
    '06 SR5 AC V8 4WD
    Skid plates?...
  13. Dec 28, 2024 at 8:16 AM
    Richid
    Richid New Member
    Mine still makes this same sound due a broken rear leaf. I'll replace it one of these days.
  14. Feb 10, 2025 at 1:37 PM
    inv3ctiv3
    Jim Bob
    Well it was something obvious I should have noticed when I installed all the new suspension....The UCA was hitting the coil bucket under load and the reason it did it before and after the TC install was the JBA UCA's the previous owner installed had also been hitting. Turns out the casting on my coil bucket was off so it was contacting the upper arms. 5 minutes with a grinder fixed it lol.
    Mustanley and BroHon like this.
