Clunk noise from rear of stock suspension
Discussion in 'Suspension' started by jordoncloutier, Jul 5, 2021.
  1. Jul 5, 2021 at 6:20 AM
    jordoncloutier
    jordoncloutier [OP] New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    Hey guys ,
    Wanted to check If anyone has had a similar issue before I take it in for warranty diagnosis ,
    2019 SR5 Crewmax 4x4 stock non trd suspension black shocks , Theres a clunk / single Pop noise from rear end when articulating the rear axle , I hear it every time I enter my driveway or if I were to go over a curb or something. At first it sounded like a loose spare tire but I double checked it and its tight .
  2. Jul 5, 2021 at 6:44 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    It's pretty normal, you can grease the leaf spring eyes to see if it helps, there's lot of things to flex on a BOF vehicles, every one of my trucks do that, that includes GM/Ford/Ram/Toyota
    jordoncloutier[OP] likes this.
  3. Jul 6, 2021 at 8:45 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Does your truck have a rear sway bar? If so, the links may be loose.
  4. Jul 6, 2021 at 8:55 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Go under and re torque every nuts and bolts
