Clunk Noise After Putting In Drive
Discussion in '2.5 Gen Tundras (2014-2021)' started by TXTruck59, Jul 29, 2024.
  1. Jul 29, 2024 at 10:40 AM
    TXTruck59
    TXTruck59 [OP] New Member
    2017 SR5 Tundra
    My truck recently started making a clunking noise whenever I put it into drive or reverse. I noticed it only does it after sitting for a while like when I go to work in the morning. I greased all the u joints but its still making the noise. The truck only has 85k miles on it.
    I took a video of the noise here.
    https://www.youtube.com/shorts/QcVJ3DVybO0
  2. Aug 1, 2024 at 6:36 PM
    d33pt
    d33pt New Member
    That's just the normal ABS check I believe. Both of mine do it.
    1UP likes this.
  3. Aug 2, 2024 at 11:24 PM
    TXTruck59
    2017 SR5 Tundra
    What's that you mean? If it was normal wouldn't it have done it since I got it?
  4. Aug 3, 2024 at 10:26 PM
    Msquare
    Msquare New Member
    Marty
    I bought my 2020 with 18k on it and it’s done it everyday I start it up and go.
    It’s the ABS check.
    1UP and QuikreteTundra like this.
  5. Aug 4, 2024 at 4:46 AM
    Retired...finally
    But the ABS check on mine happens at 6 MPH.
    1UP and 18DCTRD like this.
  6. Aug 4, 2024 at 8:29 AM
    TXTruck59
    2017 SR5 Tundra
    So does it do the ABS check everytime you shift from drive to reverse or reverse to drive? This almost sounds like something's broken inside the drive shaft. I'm not entirely convinced because the other guy below said his happens at 6mph. I've read other threads saying some people have it at 15mph. This happens when the truck is still, driving around I don't hear any noise.
  7. Aug 4, 2024 at 10:52 AM
    SoCal_Tundra21
    SoCal_Tundra21 New Member
    Can you hear it inside the cabin? If so can you post a video? I have a 21 with 140k, I bought it recently. When I first start the truck and put it into drive, there is a weird grinding / clunking noise when it shifts to 2nd gear. Not sure if it is the same thing
  8. Aug 4, 2024 at 9:45 PM
    TXTruck59
    2017 SR5 Tundra
    In the cabin, I can only hear if I lower down the window. I don't hear any noise when driving. The sound you hear in the video is what I hear.
  9. Aug 4, 2024 at 10:04 PM
    rcsbguy
    rcsbguy New Member
    Grease your driveshaft so you can weigh that out of the possible culprits.
  10. Aug 4, 2024 at 10:34 PM
    j_supra
    j_supra Dreamin about boooost!
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub, Rokblokz XL, AVS visors
    Do you feel it as well or only hear it? My truck does something similar and it's the carrier pin in the rear diff. Common on higher mileage tundras. Mine has over double the mileage yours does though. And mine is much more noticeable when the rear diff is warm.
  11. Aug 5, 2024 at 11:14 PM
    TXTruck59
    2017 SR5 Tundra
    I don't feel anything weird in the cabin, only hear it.
  12. Aug 6, 2024 at 1:13 AM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    Hmm. Ok. Maybe Jack up your rear end and grab the drive shaft and twist it back and forth and see if you have abnormal amount of play or backlash in the rear diff. If you do, I'd suspect carrier pin. If not, must be something else and I have no idea.
  13. Aug 6, 2024 at 3:29 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    That sounds like bushings or leaf springs loading up. Have you been in a very dusty environment lately?
  14. Aug 6, 2024 at 12:19 PM
    TXTruck59
    2017 SR5 Tundra
    Yeah... I was on vacation and went offroading with it some 200 miles in Arizona
  15. Aug 6, 2024 at 1:07 PM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    From what I can hear that is normal.
  16. Aug 6, 2024 at 7:16 PM
    TXTruck59
    2017 SR5 Tundra
    Just curious why, did a bunch of dust, maybe some rocks too, get all lodged up in there and its causing the noise?
  17. Aug 7, 2024 at 4:40 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    It always amazes me where I find dust after spending time off-road. Muddy water as well. It will go everywhere and things will never be the same :)
    Now your bushings and springs are not riding/setting on nice clean surfaces any longer. As they move the dust and dirt are obstructing their normal motion against each other. Not much but a little. This obstruction causes the creaky sound that you are showing. With some time and some rain this will improve.
  18. Aug 7, 2024 at 7:40 AM
    TXTruck59
    2017 SR5 Tundra
    That makes alot of sense. It was my first time offroading that much since I got the truck so the sounds scared me at first. :eek:
    It does show how tough these trucks are from what I put it through.
    From what I could gather nothing under the truck seemed worn out, there is just alot of dust everywhere. I have noticed in the past two days, the sound is less harsh so that would probably explain it. Going to give it some more time and see how it goes. Thanks alot
  19. Aug 7, 2024 at 9:45 AM
    QuikreteTundra
    QuikreteTundra Previously owned '16 Tacoma SR5 Pro
    '21 Tundra Cement TSS OR 4x4 | '23 T4R Lunar TRD ORP
    Thank goodness someone said this. I was wondering the exact same thing and it happens every time at start up around 7+mph mark. I will say, that sometimes it is a more aggressive sound to where it's a harsh clunk but that doesn't happen very often. It's mostly always just the typical minor clunk noise when speeding up from a cold start.
  20. Aug 9, 2024 at 12:42 PM
    Msquare
    Msquare New Member
    Marty
    Sorry I didn't get back to this sooner. To clarify, when I start my truck, put it in drive and roll forward, at around 5 mph, I get the clunk noise.
    I will check to see if it is only the initial start up or if it happens every time.
  21. Aug 9, 2024 at 8:31 PM
    TXTruck59
    2017 SR5 Tundra
    No problem. The noise on my Tundra has been very minimal the past few days. I think its what @mverkaik said, bunch of sand and dirt under my truck. I'm not worried about it anymore
  22. Aug 12, 2024 at 6:38 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    The only thing I see is that your carrier bearing looks crooked. May be a normal position, I haven't looked at mine to check. But I THINK those slots should be even. I could be wrong.
