Clunk noise after coasting
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mcrase00, Jan 29, 2025.
  1. Jan 29, 2025 at 7:11 PM
    Mcrase00
    Mcrase00 [OP] New Member
    2019 Tundra SR5
    When I’m coasting from say 50 down to 15ish and then give it just a little bit of throttle to maintain that speed I get a noticeable and audible clunk like a gear is reengaging. It definitely doesn’t feel like the drive shaft but maybe the transmission. Other wise it’s shifts pretty smoothly. Anyone else experience this?
    FabioXc likes this.
  2. Jan 29, 2025 at 8:16 PM
    lr172
    lr172 New Member
    07 DC
    Sounds like too much wear in the rear differential. There is some slop between ring and pinion gears. When you coast, the gear mesh moves to one side of the engagement because of the fuel cut and the drag it creates. When you hit the gas, it moves back to the other side of gear engagement. Normally this can be felt if paying close attention, but otherwise unnoticeable . If you have too much clearance there, this can become loud and noticeable. Not saying that is the problem, but is a possibility.
    chock the tires and put truck in neutral. Then rotate driveshaft back and forth and listen. Then compare to other truck for normal. Watch the pinion shaft/flange as you do this . If you see any axial movement or side to side slop, the pinion bearing is shot.
  3. Jan 30, 2025 at 2:01 PM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    Mine does act like this. It seems to be the rear axel. Doesn't like slow and go on the highways. Pretty much has been this way since new. I have to baby the throttle to prevent it.
  4. Jan 30, 2025 at 3:52 PM
    Mcrase00
    2019 Tundra SR5
    Thanks for the input! It doesn’t do it all the time but seems to happen when the rpm’s drop below 1k and coasting right when I tap the accelerator. I will try your advice soon!
  5. Jan 30, 2025 at 4:26 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Hello,
    Welcome to the forum.
    Try introducing yourself first and we'd be happy to help you.
  6. Jan 30, 2025 at 5:25 PM
    Mcrase00
    2019 Tundra SR5
    Hello, thanks for the help. Long time Toyota owner, first tundra. Iv got a 2019 with 37k miles. Been reading through a ton of forums and couldn’t find quite what I was looking for.
    Toyotoholic likes this.
  7. Jan 31, 2025 at 2:22 PM
    FabioXc
    FabioXc New Member
    None
    You got a video of the sound it makes ? Just curious because I might have the same issue but also my spare tire makes a lot of noise sounds like a cluck as well
  8. Jan 31, 2025 at 2:52 PM
    Adamace1
    Adamace1 New Member
    None....
    CLLLLUUUUNK...
  9. Jan 31, 2025 at 3:27 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Not sure you truck has driveline zerks ,my 2016 does but I think they went away in 2018.....if your truck has them pump some grease in the driveline zerks and ujoints. Any dryness in the drivline = vibration and clunks
    FabioXc likes this.
  10. Jan 31, 2025 at 4:32 PM
    Mcrase00
    2019 Tundra SR5
    @FabioXc right now I don’t have a video. It’s not really something I can always replicate. I’m thinking it’s slack in the drivetrain. It seems to do it when slowing down (coasting) and rpm’s drop way down when coasting around 15ish mph and right before it down shifts another gear. If I press the gas while it’s in between coasting at a low speed with low rpm’s and before it down shifts is when the clunk happens.
    @frichco228 I definitely don’t see any zeros to grease but I read where you can pull the boot off right after the carrier bearing and grease that but you need a new boot, new clamps, and a clamp tool. I’m not sure if I even read that right but that’s what I got out of it.
    FabioXc likes this.
