Clockspring replacement help
Discussion in '2nd Gen Tundras (2007-2013)' started by e30cabrio, Jul 4, 2022.
  1. Jul 4, 2022 at 11:28 AM
    e30cabrio
    e30cabrio [OP] I'm e30cabrio, I'm a modaholic
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I replaced my clockspring with an OEM 300.00 unit, followed the videos & instructions I found 100% spun the clockspring until there was resistance, spun it back, counted 5 turns (it said 5 turns on it) & spun it back 2.5. Need to figure it out, I have a total of 3 16.00 eBay CS coming but prefer to only use 1.
    I'd appreciate insights into what went wrong so I don't have to do this over & over.
    Thanks
  2. Jul 4, 2022 at 1:45 PM
    e30cabrio
    Has anyone used these CS? it looks like it has a lock I'm hoping is the center.
    D4x4TRD likes this.
  3. Jul 4, 2022 at 2:39 PM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    2012 Sr5 DC TRD 4x4 Blaaaaaack baby 4.6liter
    Blacked out front grill badge Bigger tires 305/60r18 Tonneau cover
    I used what looked like that when I replaced my lockspring. The orange tab is left in place intil the last second before install. That clockspring comes ready to install without setting anything. Just make sure you put it back in as the old position. Good luck
  4. Jul 4, 2022 at 2:51 PM
    e30cabrio
    Thanks!
    D4x4TRD likes this.
  5. Jul 5, 2022 at 5:28 AM
    Lead Foot
    Lead Foot 2007 DC 4.7L 4X2
    Indiana
    2007 SR5 Double Cab Black 4.7 4X2
    I just replaced mine over the weekend ($15 on eBay). Pull the pin just before installing the steering wheel. Solved my intermittent cruise control issue.
    baraynavab and e30cabrio[OP] like this.
  6. Jul 5, 2022 at 5:51 AM
    e30cabrio
    Thanks!
  7. Jul 5, 2022 at 12:46 PM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    That $300 unit has the electronic modules on it already. The less expensive clockspring units require that you remove those modules from the old clockspring and put them on the new one. I had to do that on mine. It is what makes the less expensive units less expensive. It is just the clockspring without the electronics.
    baraynavab likes this.
  8. Jul 5, 2022 at 5:24 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    So I don't know about the more expensive clock springs. I had a $13 ebay one replaced on my truck that had issues with cruiser and horn. Replaced it and both worked no problems.
    So even if you need to exchange the electric components from your old clock spring. I think it's worth it to get the cheap one and get them replaced. Must not be too hard. Just be careful and it can be done.
  9. Jul 10, 2022 at 5:23 PM
    SHAYNDRA
    SHAYNDRA New Member
    I usually perform a thorough cleaning to a faulty module or attempt to fix it before I buy because I cleaned the CS on this truck and the CC is working again.
