Clock spring srs issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by kcodoley, Aug 10, 2023.
  1. Aug 10, 2023 at 4:28 AM
    kcodoley
    kcodoley [OP] New Member
    2015 TRD Pro
    I know this issue has been discussed a lot, especially the process of replacing. My issue is now that I have done the swap, my horn works, but the air bag system is showing a fault. Sent the ebay seller a message and they sent a replacement clock spring. The second one now has the same issue. I reset the srs code last night when I did the swap and thought it was good. However this morning it came back on. I haven't had a chance to scan the code again yet, but the first time around it was for an open circuit in the squib for the driver air bag. I'm really frustrated and have taken this part off and put it back on at least 5 times now and the issue remains. Should I just buy the oem version for 10x the cost, or do these cheaper ones actually work!?!?
    Thanks
