Clinking noise from the rear
Discussion in 'Suspension' started by Klingon4x2, Jan 12, 2024.
  1. Jan 12, 2024 at 6:55 PM
    Klingon4x2
    Klingon4x2 [OP] New Member
    2006 Tundra 4x2 Double Cab
    None
    I have a 2006 4x2 Double Cab. I hear this clinking sound coming from the rear every time I take off.
  2. Jan 13, 2024 at 9:08 AM
    fallen0
    fallen0 New Member
    Minnesota
    2017 Tundra TSS OFF-ROAD, 2020 Mazda CX-5, 1997 Mazda Miata
    Taking off from a stop? Does it happen when switching from drive to reverse and back?
    Likely a driveshaft U-Joint.
  3. Jan 22, 2024 at 11:43 PM
    Klingon4x2
    None
    It is the mid-shaft support bracket bearing or many call it the carrier bearing. I changed it and the middle U-Joint as well. The noise went away. I noticed some YouTube videos on the remove-and-replace. It talks about the orientation of the bracket bearing. I bought my carrier bearing from Oreilly's. The manufacture is Precision. I did not notice any forward pointing arrow on the bracket. Is the orientation that important? Which is forward and which is up or down (cup side or flat side)? Again, I have a 2006 4x2 SR5 Tundra.
