climate control lighting
Discussion in 'Lighting' started by ladywolf, Sep 20, 2017.
  1. Sep 20, 2017 at 4:39 AM
    ladywolf
    ladywolf [OP] New Member
    Kristen
    Clarksville TN
    05 S45 4x4 Double cab Jade Green Mica
    2.5" eibach coils/springs
    Has anyone ever had issues with the lighting for their heat and AC adjustment knobs?
    I noticed last night that the heat/cold barely illuminates, and the fan switch (off-high) doesnt illuminate at all.
    If anyone has a link to the replacement, and the bulb types needed, that would be greatly appreciated!!!
  2. Sep 20, 2017 at 5:25 AM
    whiteTRD'02
    whiteTRD'02 New Member
    I don't have a link or bulb #, but here is the bulb and how to get to it. My bulb on temp control quit last year.
    Off topic: I didn't know there was a glove box light. In 16 years, I've never seen it lit. Bought a new bulb and it won't stay in the connector.
  3. Sep 20, 2017 at 6:24 AM
    ladywolf
    Kristen
    Clarksville TN
    ok. its some kind of neo-wedge. My question is....where exactly is the bulb in the dash cluster. is it in the trim piece, or behind the black plastic when you get the trim panel off, where the blenders are for the control knobs?
  4. Sep 20, 2017 at 8:55 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Hi Kristen. I'm 99% sure that the bulbs you need are a #74. They're a miniature wedge bulb. Wish I could help more with the location, but the best I can tell is that they're going to behind the trim panel and the small panel behind the trim. Remove a few screws and the small panel should pull straight out.
    whiteTRD'02 likes this.
  5. Sep 20, 2017 at 3:57 PM
    whiteTRD'02
    So....I posted the incorrect bulb. I purchased it from the dealership for this. My apologies ladywolf.
    I ended up taking the 5 screws out in the picture above. This is what I found:ee419114541f6ec8c517f205a2921782_dcebd114ef4ec2add2b2e664ab8eaca260bf39c8.jpg
    There are the 3 bulbs.
    1a1d05ff9f5ba58cecfa448055c718c9_d9fd6aad0e877d20480ee42afb7036b4f56e28ef.jpg3cf3982c96034258bac217291442ebed_2324f9995445a4dd1bc5448fd99b6b7e1c41b196.jpg
    I think I might just have it!
    If you haven't yet taken the 5 screws out, it's a tight fit,so take your time. Pull straight out, working it from the top, then around it. There's clips that need to release and plastic studs that can break if pulled off at an angle. Once you get that off, that's it-no need to disconnect anything.
    Just carefully roll the green rubber half way and slide it off. Reverse it all to install. Good luck and thanks
  6. Sep 20, 2017 at 3:59 PM
    ladywolf
    Kristen
    Clarksville TN
    ah sweet!!! Thank you!! I was wondering if the lights were on the back of the center dash or in the motor area. Thank you very much!
    Where did you get your service manual??
  7. Sep 20, 2017 at 4:08 PM
    whiteTRD'02
    From these guys, in October '01.df8542bab31952750cd01b71c4ad107e_8c49943b5b80cfc9cca60c1a708b6a0edc6fb8c2.jpg
    Very welcome !!
  8. Sep 20, 2017 at 5:02 PM
    ladywolf
    Kristen
    Clarksville TN
    how much did it cost you, if you dont mind me asking?
  9. Sep 20, 2017 at 5:09 PM
    whiteTRD'02
    If I remember correctly it was around 3 hundred. My wife downloaded a free manual for our tractor. Maybe that's an option for your truck.
  10. Sep 20, 2017 at 6:45 PM
    whiteTRD'02
    There's a couple things I realized might help you. Grasp the control knobs with your fingers (try not using pliers)real tight and pull straight off-no side to side or wiggling or it could easily break.
    The 4 yellow plastic clips at the end of each stud on the back need to release. There is a fifth clip at the top that needs to release 1st. Again, try not to use a screwdriver or anything. Just pull from the top of vent area.
    Anyways, one of the yellow clips popped of the stud (you can see it missing above) and was hiding from me for an hour. Thankfully, I had some help come out and we found it!1635cf5d571baebb618a440e754c5c92_1305f005c0e889c5af01439141e60c3c14884d81.jpg
    Had to take the glove box down to find it. Bad picture, but it's down in the crack.
    I really hope you get 'er done!
  11. Sep 20, 2017 at 6:47 PM
    ladywolf
    Kristen
    Clarksville TN
    Thank you again! It'll be a couple days....waiting to get paid. I also have maintenance on my 4runner to catch up on.
    whiteTRD'02[QUOTED] likes this.
  12. Jul 2, 2020 at 8:40 PM
    02 Sequoia Limited Black
    02 Sequoia Limited Black 2002 Sequoia Limited 4x4
    Alan
    Albuquerque
    2002 Toyota Sequoia Limited 4x4
    3" factory lift
    It's a T5 bulb I believe ma'am
  13. Jul 2, 2020 at 8:43 PM
    Alan
    Albuquerque
    3" factory lift
    I used the OE housing, and plugged these in Screenshot_20200702-214227.jpg Screenshot_20200702-214227.jpg
  14. Sep 5, 2020 at 6:40 PM
    shootemintheface
    shootemintheface New Member
    01' Tundra V8 Limited New Frame
    What are the two light bulbs circle in red for? It tried to replace them with led bulbs but need to figure out what they're for so I can figure out if the bulbs are working or not.
  15. Sep 6, 2020 at 8:14 AM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    Will these work in a 2011 SR5?
