Climate control doesn’t retain memory after shut off
Discussion in '2nd Gen Tundras (2007-2013)' started by Scree-Doze, Mar 7, 2020.
  1. Mar 7, 2020 at 5:01 PM
    Scree-Doze
    Scree-Doze [OP] New Member
    2007 Crewmax Limited
    If I turn my heat or Ac set to high and turn the vehicle off, the next day when I start the truck, everything is off. I have a remote start on the vehicle and it’d be helpful to be able to set for heat and defrost before getting out so that they turn on when I remote start in the morning. Any ideas on how to fix this?
  2. Mar 7, 2020 at 5:02 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Nothing to fix. That's how it was designed.
  3. Mar 7, 2020 at 5:03 PM
    Scree-Doze
    That sucks. But thanks, I’ll stop looking for blown fuses.
  4. Mar 7, 2020 at 5:19 PM
    biebs96
    PA
    It should resume to the last known setting.
    I see it’s a limited.. so you have auto climate control.
    If it isn’t or doesn’t turn on there is most likely a problem with one of the servos or a problem with the climate control ecu.
  5. Mar 7, 2020 at 6:58 PM
    Failure2comply
    Failure2comply Master HVAC Tech
    VA
    2008 Tundra Crewmax Limited w/factory 20" wheels
    Trailer brake. Limousine tint in rear windows. Ultra Gauge "Blue". Toyota bed mat and bug deflector.
    My Limited retains its set points.
  6. Apr 29, 2020 at 4:58 PM
    570Explorer
    570Explorer New Member
    Did the OP's question ever get answered?
  7. Apr 29, 2020 at 5:20 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    mine retains the setting, heated seats included with my remote start.
  8. Apr 29, 2020 at 5:32 PM
    Scree-Doze
    Op here. Yes. Working properly, the climate control should retain settings. What I found was that there was a physical wire caught in the gears by the drivers right shin. The gears control the doors of the climate system and that wire jacked it all up.
    I took it apart but for the life of me can’t get the whole thing synced again. Need to take it apart and give it another go.
    BravoDeltaRomeo likes this.
  9. Apr 29, 2020 at 5:32 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Does you defrost and/or A/C retain?
  10. Apr 29, 2020 at 7:03 PM
    biebs96
    PA
    I had this issue on my 10 limited. After countless hours searching and working with a Toyota master mechanic who became very involved because he was determined to find a solution.
    The end result was the climate control ecu had malfunctioned causing the servos to move at incorrect times and bind.
    The unit extremely expensive and basically the whole dash had to be removed to access getting it out, so I passed on fixing it.
  11. Apr 29, 2020 at 7:07 PM
    570Explorer
    Thanks Scree
    Can you elaborate a little?
    My 2010 Tundra Crewmax Limited has retained it's climate settings for 10 years
    I killed my battery last week leaving the bed light on
    Since restarting the truck using a battery charger I have to manually turn the climate system on each time I turn the ignition off
    JPritch likes this.
  12. Apr 29, 2020 at 7:11 PM
    Pudge
    CT
    Yup
  13. Apr 29, 2020 at 8:19 PM
    570Explorer
    Wow!
    Hope there is another reason
    So you've been manually controlling your temp after every restart?
  14. Apr 30, 2020 at 3:10 AM
    biebs96
    PA
    I did for about six more months then sold the truck.
  15. Apr 30, 2020 at 6:11 AM
    570Explorer
    That's one way to solve the problem
    Hope there's a simpler way
  16. Apr 30, 2020 at 6:22 AM
    biebs96
    PA
    I was already looking at upgrading to a 3rd gen.
  17. Jun 2, 2020 at 6:37 PM
    570Explorer
    Need some advice
    As mentioned in previous posts, climate control not holding settings in memory
    Now both heater and AC working at the same time
    Dash vents blow cold (cool) air
    Center console vents blow hot air
    Taking off on a road trip into the heat in 2 days
    Any advice on how to deactivate the heater at least temporarily?
