Climate Control Cluster off, system still running (+hot), no power windows
Discussion in '2.5 Gen Tundras (2014-2021)' started by curiouslynimble, Jan 18, 2024.
  1. Jan 18, 2024 at 2:50 PM
    curiouslynimble
    curiouslynimble [OP] New Member
    Hello all. 2014 Tundra Limited TRD, purchased used from a dealer a year a couple years ago.
    I live in the PAC NW and had an ice storm roll thru here recently. I went to deice my truck, turned it on, jacked up the temp control to max + defrost, came back and everything was running but the auto temp climate control cluster was dead.
    It also seemed to kill all my power windows, but driving was fine (minus the cab being swelteringly hot without the ability to open windows).
    I'm assuming i've blown a fuse here, but after reviewing the various fuse diagrams I cannot seem to narrow down the ones that would power that particular cluster. I've checked a number of (seemingly) obvious ones, but my experience is very limited here...
    The head unit works fine, but it's an aftermarket one (not sure if that matters).
    I'm definitely a novice but know the basics as far as testing fuses and relays. Wondering if any of you fine folks on here could help me out.
    I don't usually turn to forums for something as i fully expect to be told i'm an idiot (i am) or getting blasted for not seeing a previous post (i spent far too much time already searching), but I thought it worth a shot.
    Thanks in advance, or you're welcome for giving you new fodder to yell at...
    Dave
  2. Sep 3, 2024 at 12:12 PM
    Bryanfain
    Bryanfain New Member
    North Ga.
    2016 TRD Pro
    Maggy SC, JRT sound System, AFE intake,
    I have the exact same problem. Did you ever figure it out? I found the 30a PWR 2 fuse to be blown but it just pops as soon as I replace it.
