Click Sound!?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tsm503, Aug 30, 2022.
  1. Aug 30, 2022 at 10:36 PM
    Tsm503
    Tsm503 [OP] Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    Hearing a click sound coming from under the truck when putting cold engine into reverse when pulling out of driveway. I’ll put it into drive and then into reverse and it won’t click. It only does it when I first start up the truck and put it into reverse for the first time during a commute. Thoughts?
  2. Aug 31, 2022 at 4:26 AM
    SR5BART
    SR5BART New Member
    Bart
    Chicago
    21 SR5 TRDOR
    At 6mph the ABS actuator does a self check and makes a click type sound. See if you get the same sound when you first start the car but put it in drive. At exactly 6mph you should hear it. It will do it every time you start the truck and you start moving either forward or backwards.
    Otherwise you might be hearing pad shift
    I hope that helps
    LS3 and tweetlessfeags like this.
  3. Aug 31, 2022 at 6:29 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    ^ yup... either the ABS check or the brake pads shifting in the calipers.
  4. Sep 1, 2022 at 10:14 AM
    Tsm503
    2021 DC SR5
    I’m familiar with the ABS check. This is not it, sounds a little metallic. Almost like taking two small 10mm wrench’s and tapping them together. Could that be the break pad shift you are talking about?
  5. Sep 1, 2022 at 3:05 PM
    Netmonkey
    Georgetown, TX
    possibly. could you take a video of it?
  6. Sep 1, 2022 at 4:57 PM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
  7. Sep 1, 2022 at 8:10 PM
    Tsm503
    2021 DC SR5
    I want to say that the sound is very similar. Only have 6k on this truck. Is that a part that goes out quickly?
  8. Sep 2, 2022 at 5:16 AM
    Netmonkey
    Georgetown, TX
    interesting. The carrier bearing should not go out in 6k miles though… unless it was bad to begin with.
    OP, does the noise happen right when you put it in gear or when the truck starts to move? Is the sound coming from the front of the truck or from the rear of the truck?
    I thought of something else. It could be your lower control arms shifting. When I had my truck lifted, I got an alignment done and after a day or so of driving, I would get a loud click or thunk when I transition from moving forward to reverse and vice versa. It turned out that the alignment shop did not torque the cam bolts tight enough and the control arms were shifting back and forth. That could be a possibility on a new truck.
    That is something that you can easily check. Crawl under your truck and see if you can tighten those bolts more.
    g6t9ed[QUOTED] likes this.
  9. Sep 2, 2022 at 5:49 AM
    g6t9ed
    Yeah, wasn't aware you only have 6k on the truck. I agree with @Netmonkey that the video I posted would be highly unlikely in your scenario and re-reading your statement about it happening only on cold start would also discount what I was thinking.
    Tsm503[QUOTED][OP] likes this.
  10. Sep 2, 2022 at 10:05 AM
    Tsm503
    2021 DC SR5
    Only happens about half a second after I initially put it into reverse, even without moving. I can back out of my driveway, put into drive, then back into reverse and no sound. I believe it sound like it’s coming from right under the front seats
  11. Sep 2, 2022 at 10:37 AM
    Netmonkey
    Georgetown, TX
    odd.. maybe it is the transmission going into gear? is this on a 2022 model? no lift? try to capture this on video or have a friend look under it while you put it into gear. it is hard to further diagnose without seeing or hearing it.
  12. Sep 2, 2022 at 11:08 AM
    Tsm503
    2021 DC SR5
    2021 model, I’ll try and see if I can get a video of it
