CLICK once with no start 2011 tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by Danjojo55, Sep 27, 2021.
  1. Sep 27, 2021 at 4:13 PM
    Danjojo55
    Danjojo55 [OP] New Member
    2011 Tundra
    started truck this morning moved it 50 ft and parked, shut off. Later in the day tried to start but only one click no start and instrument lights go off. Released key and turned off, tried again. One click and loss of instrument lights. Any suggestions?
  2. Sep 27, 2021 at 4:15 PM
    How old is the battery?
  3. Sep 27, 2021 at 4:48 PM
    Danjojo55
    2011 Tundra
  4. Sep 27, 2021 at 7:02 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    How tight are the terminals? How new is new?
  5. Sep 27, 2021 at 7:10 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Starter, but first, try jumping it through the relay. Get the battery tested and rule those 2 out.. mine did that when my starter went
  6. Sep 27, 2021 at 7:45 PM
    Danjojo55
    2011 Tundra
    Today new
    Terminals double checked as to clean and secured.
    I will try jumping across the relay in the morning. Thank you
  7. Sep 28, 2021 at 12:42 AM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    1.) make sure its in park an try it
    2.) check battery voltage for 12v
    3.) put it in Neutral and try again
    4.) jump starter relay (if works)
    5.) check brake light that they come on while depressing the brake pedal
  8. Sep 28, 2021 at 10:20 AM
    Danjojo55
    2011 Tundra
    After jumping the starter relay i still only get a click from the starter solenoid.
    I have some appointments today but might get back to pull the starter later today
    Thanks everyone
    I will confirm its a bad starter before I purchase a replacement.
  9. Sep 30, 2021 at 5:49 AM
    Danjojo55
    2011 Tundra
    Finally got back to my truck and removed the starter.
    I powered it up and found the motor to turn rather slow so off to the parts store. They also bench checked it and confirmed it bad. Purchased a new one and installed it. Hooked up the battery, hit the key and sure enough the engine started, all is well.
    I’m a bit thick headed and just couldn’t believe the starter was bad, not having any previous problems.
    Thank you to all for your suggestion.
    g6t9ed likes this.
  10. Sep 30, 2021 at 6:12 AM
    blackdemon_tt
    I did the same thing... Took me a week to accept it, and replace it lol..
    g6t9ed likes this.
