Cleanly route wires to the rear bumper
Discussion in '2.5 Gen Tundras (2014-2021)' started by Calebrichardson85, Oct 17, 2020.
  1. Oct 17, 2020 at 3:00 AM
    Calebrichardson85
    Calebrichardson85 [OP] New Member
    Sorry if this has been discussed before, but I’m having trouble finding a way to cleanly route wires to the rear bumper of the truck to install my flush mount led pods. Anyone have any pointers to run the wire from the front to the back of that truck?
  2. Oct 17, 2020 at 4:56 AM
    timsp8
    NY
    I just ran a pos and neg from the battery to the bed and went along the drivers side frame. It runs next to the gas lines for a couple of feet, then beside the gas tank, then just up and over the frame crossbars under the bed. Took about 20 feet or so of wire. I used 10 gauge due to the length, but your lights not need that much. Get a wire loom too.
    Calebrichardson85[OP] likes this.
  3. Oct 17, 2020 at 8:16 AM
    Calebrichardson85
    They are rough country 2” pods that came with the rear bumper. They already have a harness built. So instead of running it through the cab you just ran it down under the engine bay all the way back?
  4. Oct 17, 2020 at 1:46 PM
    timsp8
    NY
    Yes. If you are going to the battery, no reason to go through the cab. It’ll add unnecessary holes and frustration on you. I’ve run some in to the cab and it’s a pain if you go through the rubber grommet in the firewall. Just get the wire loom and plenty of zip ties.
    The switch will have wire run in to the cab though. You can try the firewall grommet or there are several other rubber plugs under the truck you can run through and fish it under the carpet. Just seal it afterwords.
  5. Oct 17, 2020 at 3:20 PM
    Gto7419
    Gto7419 New Member
    2010 Tundra
    I installed a backup camera in the tailgate handle. You will need to run a fused wire from the fuse box or battery to a switch in the car. I highly recommend stashing a relay under the hood and simply using the 12v accessory/lighter + for the switch. I used the grommet on the pass side of the firewall. From the relay or pass side firewall grommet you can simply zip tie to the frame all the way back and to the bumper.
    The added benefit of the relay and using the 12v acc circuit is that it will kill the lights when you pull the key.
  6. Oct 18, 2020 at 3:04 PM
    Calebrichardson85
    I appreciate the help guys, I got them installed.
  7. Oct 18, 2020 at 8:37 PM
    Lonestar74
    Lonestar74 New Member
    2015 CM SR5 4X4
    Did you tie into an existing switch (i.e. cargo light), or use the one provided with the bumper?
  8. Oct 21, 2020 at 5:52 AM
    Calebrichardson85
    I used the one that came with the bumper for the time being. Switch pros definitely in the future.
