Clean oxidation off headlights
Discussion in '2nd Gen Tundras (2007-2013)' started by TXTundraFan, Jul 18, 2020.
  1. Jul 18, 2020 at 9:04 PM
    TXTundraFan
    TXTundraFan [OP] New Member
    How do I get rid of the yellow tinting off my headlights?
  2. Jul 18, 2020 at 9:42 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    My 1st gen Sequoia is terrible about this. I pull the headlights and wet sand them with 2,000 grit until the yellow is off. Next, I hit it with a cutting compound and DA polisher, then buff wax on by hand. I do this every few months, got it down to about 15 minutes for both. Unfortunately, it does keep coming back. I've heard of a film you can buy to cover it after you polish them but I have no experience with it.
  3. Jul 19, 2020 at 6:58 PM
    GI Joe
    GI Joe New Member
    Joe
    ‘07 CM 4wd TuRD
    I second what JumboSlice said. For a longer lasting result, use an automotive clear coat to top coat them. I did mine on my ‘07 a couple years ago, just noticed today the clear coat is starting to chip at the top.. time to scuff and shoot fresh clear. No Yellowing to deal with.
  4. Jul 19, 2020 at 7:54 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I've had good luck with the Meguiars Headlight coating spray as a finisher. You can buy the coating separately from their headlight kits if you have other supplies.
  5. Jul 20, 2020 at 1:41 AM
    reimord
    reimord New Member
    Check out the Sylvania headlight restoration kit. It comes with a clear coat.
    Bprose likes this.
  6. Jul 20, 2020 at 4:59 AM
    0.S.T.
    0.S.T. New Member
    EAST COAST
    2007 BLACK TUNDRA 4X4 CREWMAX LIMITED 5.7 LITER
    I use 3M rubbing compound.
    Light sand w/ very fine sandpaper dipped in water. Battery powered drill working the rubbing compound.
    Works great "for me"!
    O.S.T.
  7. Jul 20, 2020 at 5:07 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I purchased brand new Toyota OEM headlight housings... they look great!
    I am not a fan of Meguiars Headlight coating spray, bug guts ate right through it within hours.
    Tundra2 likes this.
  8. Jul 20, 2020 at 5:13 AM
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
    seal them with clear coat. I just did this. SprayMax makes a 2 part kit that has primer and automotive clear coat. Pricey but worth it. My headlights came out looking new.
    deptrai likes this.
  9. Jul 20, 2020 at 6:18 AM
    Hickory Nut
    Hickory Nut New Member
    I got a RainX kit from Walmart and did my mom's VW Bug headlights $18.00. It worked Great. Just tape everything off that you don't want to scratch and follow the instructions. Comes with several different abrasive pads you chuck into your drill, you will also need a spray bottle of water. Both headlights took about an hour.
  10. Jul 20, 2020 at 9:14 AM
    GI Joe
    GI Joe New Member
    Joe
    ‘07 CM 4wd TuRD
    Also a Very good option! I didn’t realize you could get the spray separate! My Son did his car with that, came out Awesome!!
  11. Jul 24, 2020 at 11:58 AM
    ZeRussian
    ‘11 CrewMax
    awesome video walkthrough! And yes on the respirator. I have a professional respirator that has vapor and gas cartridges and I could still smell through those.
    SprayMax doesn’t even compare to the quality of clear coat like Rustoleum on anything off the shelf.
  12. Jul 24, 2020 at 12:10 PM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    You can try tooth paste.
  13. Jul 24, 2020 at 1:13 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I bought new headlights for mine partly because of the oxidation, and partly because I hit a deer. :rofl:
    deptrai and YardBird like this.
  14. Jul 25, 2020 at 5:30 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I read somewhere bug repellent works. I tried some Off! Deep Woods bug repellent on mine a couple of months ago and they still look OK. It took less than a minute for each one. They don't look perfect but they look much better than when I bought the truck.
  15. Jul 25, 2020 at 6:11 PM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    I used a 3M headlight restoration kit and it worked great however it doesn't come with a clear coat like some other kits
  16. Jul 26, 2020 at 8:51 AM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    I like the 3m kit. I have done several cars and I think it does a good job of removing the haze. I had not put clear coat on them afterwords but after reading some of the posts on here I think I am going to clear coat the next ones I do and see how well it works. I also did the bug repellent on a set one time and it works too. Not as good as the 3M kit but it is really fast. I was wondering if it works by softening the plastic so I have not done it again.
  17. Jul 26, 2020 at 8:59 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    I did the bug spray thinking what I have to lose since they were really bad. I have three other vehicles with plastic head lights that are older and none are as bad as the Tundra was.
  18. Dec 9, 2021 at 3:48 PM
    Kramegroeg2021
    Kramegroeg2021 New Member
    Mark
    2013 Tundra
    How much did you pay? Did you get LED?
    Tundra2[QUOTED] likes this.
  19. Dec 9, 2021 at 3:59 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    For OEM turn signals and headlights was right around $500.
  20. Dec 9, 2021 at 4:52 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    This is by far the best stuff I’ve ever used and it lasts. Walmart carries it too
    CERAKOTE Ceramic Headlight Restoration Kit – Guaranteed To Last As Long As You Own Your Vehicle – Brings Headlights back to Like New Condition - 3 Easy Steps - No Power Tools Required https://www.amazon.com/dp/B084RQKLV8?_encoding=UTF8
  21. Dec 9, 2021 at 5:45 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    That same box is what I used on the Corolla which I think I posted about above.
  22. Dec 28, 2021 at 6:58 PM
    Borgunit
    Borgunit New Member
    JR
    Ohio
    2013 Black Rock Warrior
  23. Dec 28, 2021 at 7:00 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    EW PT cruiser...
  24. Dec 28, 2021 at 7:11 PM
    COElkHunter
    COElkHunter New Member
    Jeremy
    2012 Silver Tundra TRD limited Crewmax 4x4
    3" OME lift w/ UCAs. ARE overland shell w/ ARE roof rack. 34" Falken Wildpeaks. ARB awning. Road shower. Wilco Offroad Hitchgate Solo High Clearance. LED lighting upgrades. Lockerdown console safe. Weathertech floormats. Duluth deluxe rear seat cover to go under the offroad approved car seats.... :P
    I vote for the 3M kit too, took 2 of them for the big Tundra headlights, but take your time and they come out crystal clear.
    TNTundra16[QUOTED] and Tundra2 like this.
  25. Dec 28, 2021 at 7:42 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Most of the headlight kits work great. I was going to get 2 part clearcoat but saw a post about using ceramic coating.
    I ordered some cheap ceramic off AliExpress and it's been holding up the past year.
  26. Dec 28, 2021 at 7:44 PM
    ThePolak
    ThePolak 2022 Platinum hunt/tow/haul/family ride on order!
    The Land of the Cobra Chicken
    I used Meguiar's Headlight restoration kit with good results. Did it a few years back and they are still clear.
