Ciggy Lighter plug in for full time USB power.
Discussion in '2nd Gen Tundras (2007-2013)' started by MoToad, Mar 15, 2022.
  1. Mar 15, 2022 at 4:08 PM
    MoToad
    MoToad [OP] New Member
    Toad
    BC Kanuckistan
    2009 Tundra DLX
    I have two of these in my dash and one in the console box between the seats. All only run when the key is on. Is there a fuse plug in to make one always on?
  2. Mar 15, 2022 at 4:14 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  3. Mar 15, 2022 at 4:22 PM
    Ernie68
    Ernie68 New Member
    Ernie
    2019 SR5 white 4x4
    Added retractable bed cover Interior carbon fiber trim
  4. Mar 15, 2022 at 4:23 PM
    FrenchToasty
    Mo
    Bone stock
    Answer: get a multimeter and start probing
    alb1k and des2mtn like this.
  5. Mar 15, 2022 at 4:24 PM
    Ernie68
    Ernie68 New Member
    Ernie
    2019 SR5 white 4x4
    Good answer. Thanks for the help!
  6. Mar 15, 2022 at 5:00 PM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    Check the amp rating between the two. I ran a fused hot wire from the battery for my always on in the console. The add a circuit was rated too low for my liking.
    Ernie68 and FrenchToasty like this.
  7. Mar 16, 2022 at 10:33 PM
    MoToad
    Toad
    BC Kanuckistan
    2009 Tundra DLX
    Reason I asked is cause I think it was my Jeep Cherokee Had a fuse in one that you could move over to a permanent power slot. Wasn't known about but asking online had someone point it out.
  8. Mar 17, 2022 at 4:50 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    On my 2007.....the cig lighter socket goes off with the key. The power outlet on the right and the center console are on a timer and go out after about a two hour time delay - enough to charge a phone for example.
    IIRC - the time delay is adjustable with tech stream
  9. Mar 18, 2022 at 11:47 PM
    MoToad
    Toad
    BC Kanuckistan
    2009 Tundra DLX
    Thanks for that jbr. Yep, mine does the same.
