Chrome Trim Corrosion
Discussion in '3rd Gen Tundras (2022+)' started by carbinefreak, May 12, 2024.
  1. May 12, 2024 at 4:52 PM
    carbinefreak
    carbinefreak [OP] New Member
    Does anyone else have Red or Orange colored spots all over the chrome Trim in the front and/or the tailgate handle? My 23 Limited is getting really bad and I want to see if Toyota will cover the replacement with 34k on the clock.
  2. May 12, 2024 at 4:57 PM
    18" TRD Off Road Wheels
    It's not real chrome so it's probably embedded debris. Possibly rail dust if it's not been decontaminated since you took ownership. I know some use Iron X to remove it, if that's what it is.
  3. May 12, 2024 at 5:00 PM
    carbinefreak
    I've had a car with rail dust on it before this isn't it, its the size of water spots. It's way bigger than what I'm used to for rail dust.
  4. May 12, 2024 at 5:03 PM
    Hella Krusty
    Hella Krusty New Member
  5. May 12, 2024 at 5:04 PM
    Hella Krusty
    Post a PIC
  6. May 12, 2024 at 5:14 PM
    carbinefreak
    Posted, I live in Colorado so they don't really salt here like they do in the mid-west or Ontario.
  7. May 12, 2024 at 5:45 PM
    Hella Krusty
    Its bits of steel flying off the plow blades on the asphalt, land on the road and tires wing it up and it embeds itself in your paint
  8. May 12, 2024 at 5:59 PM
    carbinefreak
    So is there a simple fix verses new trim pieces?
  9. May 12, 2024 at 6:03 PM
    Hella Krusty
    Send it to a detail shop. If they can get rid of it.....then spend the coin and do it yourself.
  10. May 12, 2024 at 6:18 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You can one try these if you have a DA polisher and see if it comes off.
    If not, use it on your paint once a year..
    Amazon.com: Nanoskin AUTOSCRUB 6" Surface Prep Pad Fine Grade- Patented Clay Bar Replacement Tool to Remove Embedded Contaminants Before Wax & Coating | Safe for Painted Surface, Glass, Plastic, Metal & More : Automotive
    Or this and a lot of elbow grease.
    Amazon.com: Nanoskin (AS-019) AutoScrub Fine Grade Sponge : Automotive
    You'll need a lubricant and keep it wet.
    Note this is a concentrate.
    Amazon.com: Nanoskin GLIDE Silicone Free Spray Detailer 16 oz - Use with Autoscrub/Clay Bar After Car Wash | Leaves No Residue Before Wax Sealant Coating | Automotive, Home, Garage, DIY & More | Concentrated : Everything Else
    Or use this, it's ready to go.
    Amazon.com: Chemical Guys CLY_KIT_2 Medium Duty Clay Bar and Luber Synthetic Lubricant Kit,16 oz, 2 Items, Gray : Everything Else
    I use the Nanoskin once a year with my DA polisher to remove impurities from the paint before I wax.
    YouTubes on how to use them, good luck.
  11. May 12, 2024 at 6:37 PM
    carbinefreak
    Thanks I'll give it a shot
    1lowlife[QUOTED] likes this.
