Chrome Cup Holder fix help
Discussion in '2.5 Gen Tundras (2014-2021)' started by jamesmro, Apr 24, 2019.
  1. Apr 24, 2019 at 6:05 AM
    jamesmro
    jamesmro [OP] New Member
    Has anyone changed out the chrome bezel/garnish around the cupholders? I have a Limited trim, and it reflects so much light from the sun.
    Does the SR5 truck have the same trim piece but in black? I think it's this: https://parts.battlefieldtoyota.com/oem-parts/toyota-trim-bezel-588330c060
    But I'm not certain if this one is black or if I'd end up with a second chrome bezel...I can't find a 'color' description for the part.
    Also would rather buy from Cool Springs if possible @Roman
    Roman likes this.
  2. Apr 24, 2019 at 6:15 AM
    Ostrich
    Ostrich One bit me once.
    Nikki
    Marion, Texas
    2014 MGM Crewmax SR5 4x4
    3/1 level, black leather, raptor style grille
    I'm pretty sure every trim has that in chrome. Most people either plasti dip, vinyl wrap, or paint it.
    CH1NO, sf319, yoshi82 and 2 others like this.
  3. Apr 24, 2019 at 6:16 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Most people are painting or wrapping them with the color of your choice.
    CH1NO, jewsNbrews and jamesmro[OP] like this.
  4. Apr 24, 2019 at 6:45 AM
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    Yeah I have SR5 and it’s chrome. It can really blind you when the sun is hitting at a certain angle. I see people post about vinyl wrapping stuff.. where do you get the sheets to wrap or what brand is recommended?
  5. Apr 24, 2019 at 7:09 AM
    West Texas Tundra
    West Texas Tundra 2016 Bronze Beast
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    20 inch CECO wheels Drop in K&N air filter 2 inch front leveling kit
    jamesmro[OP] likes this.
  6. Apr 24, 2019 at 7:31 AM
    jamesmro
    Wow! Thanks for this...great call. I may Plasti Dip the cup holders, and then order these AC Vent covers. Then all that's left is the shifter bezel, i believe.
  7. Apr 24, 2019 at 7:34 AM
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    I emailed tufskins and this is what they said. Sounds like we are out of luck for now. I might have to plasti dip too.
  8. Apr 24, 2019 at 7:35 AM
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    I plasti dipped mine but can now see chrome through some scratches.
  9. Apr 24, 2019 at 7:38 AM
    jamesmro
  10. Apr 24, 2019 at 7:47 AM
    Ostrich
    Nikki
    Marion, Texas
    I got this off Amazon and wrapped mine. It's pretty damn close in color to MGM. I watched a video or two before doing it and it wasn't too difficult, just time consuming.
    https://www.amazon.com/gp/product/B077Y1R5D2/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    Use a flat head screwdriver or a plastic trim pry tool and it pops right out. It's just held in by clips.
  11. Apr 24, 2019 at 9:20 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Once you remove the cupholder section of the console, you can see five or six chrome tabs that poke out and lock into the bottom of hte trim. Gently pry them back and push the locking part of the tab through the front and it'll come out easily. About a 2 / 10 on an interior work scale. I used some matte black Krylon made for plastic on mine about 3,500 miles ago. If it scratches up and gets to looking too bad, it will literally take me 8 minutes to re-paint it, start to finish (except drying time).
    aRabidLunatic likes this.
  12. Apr 24, 2019 at 9:24 AM
    Omohundro
    Jody
    McMinnville TN
    Color match it to the rest the interior. This is the only picture I could find 7CDB8F7C-4BF4-4E86-BFD1-624A92CA8F13.jpg
    tonynw318, Y0TA PR0, Pudge and 2 others like this.
  13. Apr 24, 2019 at 9:31 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    NewImprovedRon likes this.
  14. Apr 24, 2019 at 9:33 AM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    @Omohundro That is the best option I have seen so far. STAY FAR AWAY FROM PLASTI DIP. The stuff is crap and you will not like the texture.
    What color wrap was it called?
    5.7TRDProm and B737 like this.
  15. Apr 24, 2019 at 9:34 AM
    West Texas Tundra
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    So what’s the best option? Krylon? Rustoleum? With a clear coat?
    TXRailRoadBandit73 likes this.
  16. Apr 24, 2019 at 9:36 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I just hit mine with some 1200 and painted with some black matte I had in garage. About a year and a 1/2 now and no touch up. Careful prying it out you can bend and or break the plastic tabs. I bent one of mine. May or may not make it through another removal.
    B737 likes this.
  17. Apr 24, 2019 at 9:37 AM
    Omohundro
    Jody
    McMinnville TN
    Yeah, plasti dip is not something I’m going to put on my truck.
  18. Apr 24, 2019 at 9:41 AM
    Omohundro
    Jody
    McMinnville TN
    I’m sure you can find some quality spray paint, look in the oem touch up section at your loca parts store. A lot of times they have good spray paint kinda geared toward bumper repair. It’s good stuff. I did mix a color code in BASF and satin clear mine, that obviously is not an option for everyone. If someone came into my shop and asked me to do one, it would be pricey.
  19. Apr 24, 2019 at 9:49 AM
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
    I wrapped mine just so it is more durable. I like to keep a clean interior so I wipe down my interior a lot. I bought 3M 1080 Deep Matte Black Vinyl off of eBay. 5’x1’ is plenty to do all the trim in the center console.
    You also need vinyl wrapping tools which I bought off of Amazon. Like others have said, time consuming, but will be the most durable IMO.
    EDIT #1: You’ll also need a heat gun.
    EDIT #2: I would also like to add that I would probably just spray the chrome trim around the shifter. It is a PIA to wrap and didn’t look that great when I was done. I’m leaving it for now, but will just paint it when it starts peeling.
    Plumbaman, JoshR324, CH1NO and 13 others like this.
  20. Apr 24, 2019 at 9:53 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Is that just a block of foam under the cig outlet bezel, or what do you have going on there?
    jewsNbrews likes this.
  21. Apr 24, 2019 at 10:10 AM
    jamesmro
    That looks amazing...I'd rather pay you to do it, no way mine will look this good when I'm done. But I'm going to try it.
  22. Apr 24, 2019 at 10:11 AM
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    Give it a try. This was my first time wrapping. Just be patient and watch a bunch of YouTube videos while waiting for everything to come in. I’d start with the silver outermost trim around the shifter. It is the easiest and a confidence booster.
  23. Apr 24, 2019 at 10:16 AM
    offshore2005
    offshore2005 New Member
    TEXAS
    2022 Tundra Limited 4x4 RC leveling kit and 295/65/20 Cooper STT PROs
  24. Apr 24, 2019 at 10:17 AM
    jamesmro
    Will do, I'll post pics.
    Did you do any other interior trim? Chrome around the air vents, for example?
  25. Apr 24, 2019 at 10:18 AM
    MER
    MER New Member
    18' Limited CM 4x4 Off Road
    Here’s a pic showing where the clips are, so you know where to pry...
    I plasti-dipped mine and it’s been holding up fine for me.
  26. Apr 24, 2019 at 10:20 AM
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    3M makes 3 different types of matte black (Matte Black, Deep Matte Black, & Dead Matte Black). I just went with the middle one. You’ll find it cheaper on eBay. I paid $11 for 5’x1’ from MetroRestyling. I’ll update with a link once I find it. I’m sure the regular matte black will look great.
    EDIT:
    Link for 3M 1080 Deep Matte Black M22 Vinyl
    Link for Vinyl Wrapping Tools
  27. Apr 24, 2019 at 10:21 AM
    offshore2005
    TEXAS
    Is there only one color black for plasti-dip? or was this a certin type of black?.... Sorry for the questions thats just what I want mine to look like.
  28. Apr 24, 2019 at 10:21 AM
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    I have not wrapped any other trim yet.
  29. Apr 24, 2019 at 10:26 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I wrapped mine. I used a metallic gray wrap to match the trim on the dash. My first time wrapping anything so I messed up a little. I have enough wrap left over to redo it.
    16 blue crewmax and B737 like this.
  30. Apr 24, 2019 at 10:26 AM
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    Looks great. Also, both trims around the shifter will need to have the plastic rivets (I don't know what else to call them) drilled out before they can be removed. I would remove the whole center console (which is super easy) to access all the trim.
