Christmas Tree of lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by NHPig, Nov 7, 2020.
  1. Nov 7, 2020 at 8:33 AM
    NHPig
    NHPig [OP] Toyota For Life
    New Hampshire
    Super White 2016 Tundra Limited TRD CrewMax 5.7L V8
    First two still shots are from the original error of sorts. Normal ass driving in 60 degrees. Nothing stupid, commuter stuff at 40 MPH.
    Last is when I shut entire truck off and restarted it.
  2. Nov 7, 2020 at 8:45 AM
    mcm0455
    mcm0455 New Member
    2020 Tundra Platinum
    How old is your battery? I've had xmas tree lights in other cars when the battery was on its way out.
  3. Nov 7, 2020 at 9:09 AM
    NHPig
    New Hampshire
    Original, 2016.
  4. Nov 7, 2020 at 9:43 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You need to scan it to check what codes are present. Toyota vehicle will disable other systems for unrelated codes.
    NHPig[OP] likes this.
  5. Nov 7, 2020 at 10:00 AM
    I'd say battery, 5 years of New Hampshire weather.
    Go to Autozone or similar, they test batteries for free.
    NHPig[OP], Black Wolf and mcm0455 like this.
  6. Nov 8, 2020 at 1:08 PM
    NHPig
    New Hampshire
    Tested battery, appeared to be good, but needed charge... Recommended I replace before winter, so I replaced it.
    Code was listed as rear LH speed sensor.
    I removed it, douched with electrical cleaner/spray. Kept showing same sets of lights/errors, till just now, I go home and no lights were on.
    I am cautiously optimistic that it is fixed, but we will give it a day of driving tomorrow.
  7. Nov 9, 2020 at 5:33 PM
    NHPig
    New Hampshire
    Well, I applied two solutions and it ain't clear what solved it. No error codes today. Either new battery or electrical connect cleaner to the speed sensor. I'm leaning towards new battery.
    HulkSmurf14 likes this.
  8. Nov 10, 2020 at 12:54 PM
    NHPig
    New Hampshire
    And it is back... apparently I need a professional look.
  9. Nov 10, 2020 at 2:35 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Can you access the data stream with the scanner you have?
  10. Nov 10, 2020 at 2:57 PM
    trucksareforgirls2
    trucksareforgirls2 New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    Wondering if maybe a mouse got to your wiring somewhere ?
    Saltyhero13 likes this.
