Chips/CAI for better MPG?
Discussion in 'Performance and Tuning' started by theplanesaidso, May 20, 2018.
  1. May 20, 2018 at 1:58 AM
    theplanesaidso
    theplanesaidso [OP] New Member
    Hey guys, 2005 Sequoia SR5 4x4. About to hit a 3,500 mile roadtrip and wondering if anybody has had any significant MPG gains simply by installing a cold air intake and/or performance chip without modifying exaust / other components? Obviously for a trip like this I’d love to get a few extra MPG’s if possible but would it be enough to justify the hundreds of $$ for those parts? I’m not so naive to beleive the advertisements on both CAI and chips “instant 5mpg gains” etc, but just wondering if theres anything to it or not really until you modify much more on the vehicle. Thanks!
  2. May 20, 2018 at 6:09 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Only think i can think of that may help are skinny, light weight, street tires. The items you mentioned will not be helpful and only waste money. Now that I think of it, new tires would likely also be a waste on money unless you need them anyway
    15whtrd, UTTundra and Black Wolf like this.
  3. May 20, 2018 at 6:32 AM
    Use the money saved for gas for your trip!
  4. May 20, 2018 at 6:51 AM
    Pudge
    CT
    I was also going to say either do it yiurself or have it done...spend money on a good tune up. Oil, fluids, filters, diff oil, grease drive shaft, check brakes and tires (rotate and check pressure, maybe go a little higher than normal on pressure). That's money well spent and piece of mind
  5. May 20, 2018 at 7:08 AM
    15whtrd
    15whtrd Mr. Blonde
    Make sure you’ve got a clean air filter for the trip. A chip and or CAI are going to give you negligible fuel mileage gains. It would take a long time to pay off the cost of the products.
    Plus once you put those on it’s hard to keep your foot out of it anyways. Ask me how I know!
    Pudge likes this.
  6. May 20, 2018 at 7:30 AM
    Good idea... add.....battery and alternator check.. Radiator cap! Hoses!
    Pudge[QUOTED] likes this.
  7. May 20, 2018 at 7:40 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Maybe rent a minivan? You may get twice or better mileage, not sure the math works out to save money...........
    Pudge and 15whtrd like this.
  8. May 20, 2018 at 9:09 AM
    theplanesaidso
    Thanks all! Renting is not an option as I’m actually relocating the vehicle. This is perfect though, sounds like no point in messing with those. Here’s what I have done in preparation for the trip. It has 130k and the TB was done 10k ago. I just had a fresh oil change done, tranmission service, brake service, front and rear diff service and transfer case service. Tires are in great shape, 265x75x17, may air them up some though thats a good thought. Anything I should consider not mentioned above? Oh and I put in one of the reuseable K&N filters.
    ColoradoTJ and Pudge like this.
  9. May 20, 2018 at 9:28 AM
    Pudge
    CT
    Sounds like you've got the service stuff covered. I'd go up a few PSI on the tires, easiest and free mod you can make for increased mpg for a road trip.
    15whtrd likes this.
  10. May 20, 2018 at 9:31 AM
    theplanesaidso
    Awesome thanks!! A few from whats reccomended on the sidewall?
  11. May 20, 2018 at 9:40 AM
    Pudge
    CT
    Not that high. I'd say maybe a few above what's recommended on the door. Maybe 50psi or so? Assuming the tire probably says maybe 80 max, that's too high.
  12. May 21, 2018 at 8:05 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    I have drop in 12 hole injectors of the same cc as stock. They atomize the fuel better than the stock 4hole injectors. The low end torque is very very noticeable. And they take about an hour to install. Call for details. 760-877-4234
    trayday and 15whtrd like this.
  13. May 21, 2018 at 8:06 AM
    dirtydeeds
    Keith
    USA
    Newm and 15whtrd like this.
  14. May 21, 2018 at 8:07 AM
    Any for the 2nd/3rd gen Tunnys?
  15. May 21, 2018 at 8:09 AM
    dirtydeeds
    Keith
    USA
    Nah. I’ve looked into it. They’re already 12hole.
    But, Bullydog would be a fantastic tuner for 07+. I’ve done a ton of testing for Bullydog and on my own.
    Black Wolf[QUOTED] and 15whtrd like this.
  16. May 21, 2018 at 8:49 AM
    The B Dog is on my want list. I've got you bookmarked for this already!!
    15whtrd and dirtydeeds[QUOTED] like this.
  17. May 21, 2018 at 9:14 AM
    15whtrd
    15whtrd Mr. Blonde
    It’s so much more fun to drive!
    :benchpress::burnrubber:
  18. May 21, 2018 at 9:26 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Gained .5 hwy trying to get the best mileage possible with an AFE filter, getting rid of the screen in the air box and doing something similar to the SABM, just made my own. This was on a stock vehicle.
  19. May 21, 2018 at 11:48 PM
    theplanesaidso
    Wow thanks for that info! Only better torque though or MPG increase as well? Any measurable difference?
  20. May 22, 2018 at 9:54 AM
    dirtydeeds
    Keith
    USA
    I haven’t tested mpg. But it should be better. You step on the gas waaaay less.
  21. Jun 10, 2018 at 12:52 AM
    theplanesaidso
    Ok guys, back again. I pumped the tires up to the max on the sidewall (44 psi) it has 265/70/17’s on it and I’ve been driving around strictly in the city the last month. My gauge in the car shows 11.4 MPG average. Everything I read says I should be seeing 15 city/18hwy so a few questions. Is the in-vehicle le gauge (factory) not acurate? Do I have some other issues robbing MPG? Is that 15mpg just a very loose number and obviously varies heavily? With this, I’m wondering if I possibly have some brake drag or something else going on. I’ve been noticing a lot lately that after sitting stopped and taking off again right after the initial acceleration I hear/feel a noticeable but not extreme “thump”. It does not do it all the time, the vehicle sits 2-3 weeks at a time right now between drives, tranny shifts very smooth, and it was in a shop who said brakes were fine. Any thoughts?
  22. Jun 10, 2018 at 5:56 AM
    Adam New Member
    Always calculate on a piece of paper for gas mileage. After you do that, throw the paper away because you drive a huge vehicle and the gas mileage sucks. If you want to get good gas mileage, buy a car. The epa 15/18 are estimates under "perfect" conditions. Your mileage may vary...
  23. Jun 10, 2018 at 6:00 AM
    AgentOfWrath
    AgentOfWrath New Member
    Tampa Florida
    2015 Tundra Crewmax 4X4
    Flowmasters | 4 Inch Lift | Linex | Diamonback HD Cover | 40 Inch LED Light Bar \ Rock Lights
    This is my theory
    Cblowery21 likes this.
  24. Jun 10, 2018 at 8:48 AM
    theplanesaidso
    LOL thanks guys! I’m not worried about the MPG, I knew it sucked when I bought it. Just trying to make sure there’s not other issues.
