Chip… What kind? and is it worth getting to increase mpg?
Discussion in 'Performance and Tuning' started by YodaPower36, Feb 22, 2023.
  1. Feb 22, 2023 at 12:18 PM
    YodaPower36
    YodaPower36 [OP] New Member
    Ryan
    Kennett Square, PA
    2017 Tundra SR5 Double Cab
    Exterior: 3.5 rc lift Fuel Vandal 20x9 1 mm offset on 35’s, Trd dual exhaust, Spyder Industry Steps, rekgen mud flaps, Trd pro grille, Diode Dynamic SS3 fogs, YotaLED grille lights, ApexOffroad bumper shims. Interior: Heated seats, RC seat covers, Full head unit and stereo replacement. KENWOOD 1057xr, Kicker amp/sub combo,
    I’ve been thinking about doing a chip tuner for my truck. Just don’t know where to start. I am looking to get better mpg with the 5.7 I force. Open for info! Thanks!
  2. Feb 22, 2023 at 1:09 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Nope, you are not going to increase power or MPG with any chip or anything. If MPG is a concern, dont lift the truck and keep stock size, standard load tires on it. And of course driving habits have an impact. But with a truck with EPA of 13/17, even a mpg or two improvement is negligible.
  3. Feb 22, 2023 at 1:12 PM
    The 5.7 is a really old platform at this point, and Toyota pretty well wrung everything out of it. You're best bet for MPG is to not put any corn in it (only run ethanol free fuel of 87 or better octane), low rolling resistance tires in the stock size, and not adding anything to the truck. It's a thirsty engine, but it's reliable.
  4. Feb 22, 2023 at 1:14 PM
    patterson.walter
    patterson.walter New Member
    Walter
    2007 white SR5 5.7 db cab
    If you have 4x4 trade you truck in for 2x4 and then a bed cover. I get 18-19 hw with a tail wind. Lol
    Taco-Spike and TXBrit like this.
  5. Feb 22, 2023 at 1:14 PM
    Bed covers don't help MPG.
  6. Feb 22, 2023 at 1:25 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    TFL did a test and it improved their Ram by 1-2 mpg.
  7. Feb 22, 2023 at 1:29 PM
    And Mythbusters did tests that showed the only thing better than the stock tailgate up was a net gate instead. Choose who you will, but I have more faith in MB than TFL. They also did airflow models to show why.
  8. Feb 22, 2023 at 1:30 PM
    1UP
    1UP Truck Gang
    Fair enough. I'd trust MB over TFL also.
    Corndog123 likes this.
  9. Feb 22, 2023 at 1:31 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Not sure if bullydog works with a 2017 but that would be your best bet. You can talk to Keith from Dirtydeeds about it.
    dirtydeeds likes this.
  10. Feb 22, 2023 at 1:34 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    By far the best chips
  11. Feb 22, 2023 at 1:43 PM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    A knowledgeable tuner might be able to get creative leaning the fuel trims out. Truck would probably run noticeably hotter and you could possibly compromise the reliability of the engine.
    Toyota should have come out with a 3UR-FKS version of the 5.7 like they did with the 2GR V6 instead of scrapping it. D4-S port and direct injection might have brought the fuel efficiency up a little bit.
    Saltyhero13 likes this.
  12. Feb 22, 2023 at 1:45 PM
    1UP
    1UP Truck Gang
  13. Feb 22, 2023 at 4:31 PM
    patterson.walter
    Walter
    It says it on the PKG!!!!!!! Must be the best chip!! :rofl:
    WVI and Joe333x[QUOTED] like this.
  14. Feb 23, 2023 at 7:27 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Thanks!
    here’s how you get better mpg:
    bullydog
    Sabm
    Throttle body coolant bypass
    Coils and plugs
    Proper Catback
    Gearing
  15. Feb 23, 2023 at 8:25 AM
    Jjclamdips
    Jjclamdips New Member
    Wichita, Ks
    2000 Access Cab
    Why? It’s a fricking truck, what did you expect, gas mileage is terrible.
    If you wanted good gas mileage I would suggest a Corolla.
  16. Mar 16, 2023 at 4:19 AM
    Taterhawk
    Taterhawk New Member
    Nothing wrong with wanted the best mpg you can squeeze out of the worlds favorite truck!! I'm giving Keith at DD a call!
  17. Mar 20, 2023 at 7:27 AM
    ekmason
    ekmason New Member
    2021 Tundra SR5 TRD Off-Road MBM
    Keith, any tuning solutions you recommend for 21’s?
  18. Mar 20, 2023 at 7:32 AM
    Any testing or feedback on a truck with all these mods that shows what kind of improvement?
  19. Apr 20, 2023 at 10:04 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    sounds like spending a few grand,....to save $500 over the course of 10 yrs.
    And that's granting that there actually is an improvement and you have the truck that long.
  20. Apr 20, 2023 at 10:03 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    I was doing the math similarly. Quick addition on that list is north of $5K, for a pretty small gain in fuel economy. If you even see one.
    That said, the drivability should be greatly improved!
  21. Apr 20, 2023 at 11:03 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I have a bullydog. I dont think it does anything for mpg, but the truck drives much better. It removes all the hesitation, especially with shifting
  22. Apr 21, 2023 at 4:00 AM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    I would like the Knight Rider mod.
    The side to side red LED strip in the hood bulge and whatever it is that makes the truck jump over stuff.
    All other mods are a waste of time.
    KNABORES likes this.
