Chicken's Truck
Discussion in '1st Gen Builds (2000-2006)' started by stupidchicken03, Jan 14, 2021.
  1. Jan 14, 2021 at 9:48 AM
    stupidchicken03
    stupidchicken03 [OP] Team Moist
    Thomas
    In the SAC of CA
    -2002 SR5 4x4 AC -2018 Lifted XV Trek
    Method MR701 17x8.5 w/ BFG KO2 265/70/17
    As mentioned in my new member intro, I inherited this truck from my grandfather who was the original owner.
    2002 SR5 4x4 with Access Cab and just shy of 78,000 miles.
    Garage kept the vast majority of it's life. Unfortunately for it, it will be living outside for the time being. Got plans to build some sheds and an RV cover on our side yard this year, so it should be out of the sun by years end.
    Ill keep this thread updated as things come/go (if we're allowed to edit posts here - some forums don't..).
    Current Modification list
    As of:5/6/2021
    Engine
    -stock
    Wheels/Tires
    -Method MR701 17x8.5 0 offset
    -BFG KO2 265/70/17
    Suspension
    -stock
    Interior Modifications
    -LED bulbs ( https://amzn.to/3jhgPoc )
    -Rearview mirror (https://amzn.to/3gGaQu8)
    -JVC KW-M560BT headunit
    Exterior Modifications
    -Rhino Lined bed
    -Removed OEM running boards
    -Windows tinted
    -Rain visors
    Miscellaneous
    -ProTech bed tool box
  2. Jan 14, 2021 at 3:43 PM
    stupidchicken03
    Thomas
    In the SAC of CA
    Free mods are free.
    Removed the paint matched OEM running boards.
    Was pretty surprised at the minimal hardware keeping these on.
    Each side had two 13mm nuts and one 13mm bolt going to three hanging brackets off the cab. Also at each of the three brackets, there were two 10mm self tapping screws into the cab (in total 6 10mm self tapping screws, two 13mm nuts, and one 13mm bolt on each running board).
    I simply just put all the hardware back in and cinched it all down. If I ever need/want to put the boards back on, hardware is not lost and it plugs up the holes.
  3. Jan 14, 2021 at 3:55 PM
    CincYOTA
    CincYOTA New Number
    2012 Tundra SR5 DC 5.7 4x4
    Looks pristine!
  4. Jan 14, 2021 at 4:01 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
    ThatSR5Tundra likes this.
  5. Jan 14, 2021 at 4:20 PM
    stupidchicken03
    Thomas
    In the SAC of CA
    Thank you!
  6. Jan 14, 2021 at 4:37 PM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    Nice truck, i wish I still had my first gen.
    stupidchicken03[OP] likes this.
  7. Feb 3, 2021 at 1:23 PM
    stupidchicken03
    Thomas
    In the SAC of CA
    Got a cheapo LED kit for the interior lights and some exterior.
    Will probably upgrade to Diode Dynamics in the future, but for now, these will work especially some of the original bulbs had burnt out.
    kit I got: https://amzn.to/3jhgPoc
    Tundra14Platinum and YardBird like this.
  8. Feb 9, 2021 at 4:06 PM
    stupidchicken03
    Thomas
    In the SAC of CA
    Got the windows tinted.
    Back 3 are 5%
    Front 2 are 35%
    windshield is like 65% UV with a 5% sun strip across the top.
    Figured I get all my cars tinted, and this should help the interior stay a bit cooler while it sits in the sun.
  9. Feb 24, 2021 at 12:08 PM
    stupidchicken03
    Thomas
    In the SAC of CA
    Next simple "mod" arrived in the mail. Got some rain visors to put on. Since the car is living outside for the time being, figured tint and putting these on so I can leave the windows cracked will help venting heat out of the truck. For $40, fitment and quality are a 7 out of 10. The specific ones I got: https://amzn.to/2Ml0CT2
    YardBird likes this.
  10. Feb 24, 2021 at 7:07 PM
    DJS Tundra
    DJS Tundra Lots to learn
    South Alabama
    2002 White Lmt 4x4
    Wow under 100k miles that’s a unicorn.
    Awesome truck
  11. Feb 25, 2021 at 6:53 AM
    stupidchicken03
    Thomas
    In the SAC of CA
    Thanks!
    They are getting rare.. but last year a local off-road shop installed a lift kit on a Red 02 Tundy with only 40,000 miles!
    EDIT: Ok it was Sept 2019.. but here it was haha: https://www.instagram.com/p/B2SwjKqJxCw/
  12. Feb 25, 2021 at 6:59 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  13. Mar 30, 2021 at 7:12 AM
    stupidchicken03
    Thomas
    In the SAC of CA
    Hit 78k in the truck this last weekend driving to Home Depot.
    The Dude, Pearl-snap, des2mtn and 2 others like this.
  14. Mar 30, 2021 at 7:37 AM
    Congrats! I just rolled 260k on the way back from the airport. Lots of miles and smiles in your future sir.
  15. Mar 30, 2021 at 7:48 AM
    mtb-sam
    mtb-sam New Member
    Welcome - your going to love it!
  16. Mar 30, 2021 at 8:00 AM
    stupidchicken03
    Thomas
    In the SAC of CA
    I figure it's almost broken in now haha!
  17. Apr 15, 2021 at 12:46 PM
    stupidchicken03
    Thomas
    In the SAC of CA
    Dropped the Tundy off at the local dealer yesterday to get all the maint done and picked it up today.
    Mileage - 78,035
    What was done:
    -left rear axle seal and O ring replaced
    -brake fluid exchange
    -90k service (timing belt, drive belts, water pump, coolant, engine oil, etc)
    -new windshield wiper nozzles (they were plugged up) and new wiper blades
    Things they noted will/should be done soon that I opted to not take care of right now.
    -both front CV boots need to be replaced
    -power steering pump is leaking and rec to be replaced
    -new tires (they're from 2008 lol)
    -alignment
    Figure ill be doing wheels and tires fairly soon, h00ning the old rotting ones for the time being. Might do a slight lift at the same time or soon after. Will more than likely do the CV boots then, will for sure do an alignment at the same time.
    des2mtn and 81 TOY like this.
  18. Apr 17, 2021 at 9:56 PM
    jcrob33
    jcrob33 New Member
    JR
    2004 Toyota Tundra DC // 245k+
    Ya suppper low miles. Thing is awesome.
    I still would want to replace anything that’s rubber, since rubber still dies with age. Which, looks like that is indeed what you are doing?
    Any big plans?
  19. Apr 19, 2021 at 7:16 AM
    stupidchicken03
    Thomas
    In the SAC of CA
    Yea slowly replace any rotting hoses n such!
    No major plans for it as it's already a 3rd car for us. I could see in 5+ years having front and rear bumpers, but nowhere near a priority right now haha.
    Tundra2 likes this.
  20. Apr 26, 2021 at 7:16 AM
    stupidchicken03
    Thomas
    In the SAC of CA
    Wheels and new lug nuts are ordered.
    Almost got a lightly used set of the tires I want, in the size I want, for cheap.. but just missed out.
    Leo's first likes this.
  21. Apr 26, 2021 at 2:28 PM
    Professional Hand Model
    Hand Protectors
    Could be you just need new clamps on all your Power Steering Lines. My clamps gave up the ghost a few years ago and looked like maybe PS Pump Problems, but cleaned her up and installed Stainless Snake Clamps. Leaks stopped. PS Pump saved as no problems.
    FrenchToasty likes this.
  22. Apr 26, 2021 at 2:41 PM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    Still no chickens.. very disappointed. :rofl:
    there.. I fixed it. :thumbsup:
  23. Apr 26, 2021 at 4:06 PM
    stupidchicken03
    Thomas
    In the SAC of CA
    ^^ hahahaha
    Worth hopping under and taking a look for sure, thanks!
  24. Apr 28, 2021 at 11:14 AM
    stupidchicken03
    Thomas
    In the SAC of CA
    Lug nuts have arrived. If shipping is accurate, wheels should be here Friday.
    Still looking around for tires. Would like to get a set of KO2, ive got these on my Crosstrek with about 48,000 miles on them, and they have been fantastic.
  25. May 3, 2021 at 8:27 AM
    stupidchicken03
    Thomas
    In the SAC of CA
    Yesterday was stereo upgrade day.
    Installed a JVC KW-M560BT. Now have BT audio and Android Auto/Apple Car Play.
    Didnt install a backup cam at this point, but would be easy enough in the future, would just have to run the wire in.
    Also bought this off Amazon: https://amzn.to/3xySBwq to replace one of the cig/power outlets near the passenger footwell. I plugged this in for the data connection on the rear of the JVC unit.
  26. May 3, 2021 at 8:30 AM
    stupidchicken03
    Thomas
    In the SAC of CA
    Went full crazy with the wire harness. Just used wire nuts to hold everything together to test install and make sure everything was working.
    Then soldered each connection, and heat shrink over each one.
  27. May 4, 2021 at 11:46 AM
    stupidchicken03
    Thomas
    In the SAC of CA
    Wheels have arrived :D
    Method MR701 17x8.5 with 0 offset
    My ebay-aholic friend found them for CHEAP! They were listed as “BRAND NEW SHOWROOM DISPLAYS. MINOR SCUFFS ONLY” but I was slightly hesitant. I asked for pics but the office person didnt have access to the warehouse they were stored in. Decided that they are truck wheels after all and will be getting scratched up anyways, so I pulled the trigger. Got them and they literally look BRAND NEW, not a single scuff or scratch on any of them. So felt pretty good since I got them for over $300 off the new msrp :)
    Tires soon to come!
    des2mtn likes this.
  28. May 6, 2021 at 7:11 AM
    stupidchicken03
    Thomas
    In the SAC of CA
    Tires on :)
    Picked them up barely used. Came on 4runner rims too. So now ill either keep the Tundy OEM or these 4runner wheels for my trailer - but get new tires for them regardless.
    Ill throw em on the truck along with the new lug nuts on my lunch break today - perks of working from home haha.
    5N0W808 likes this.
  29. May 6, 2021 at 9:57 AM
    stupidchicken03
    Thomas
    In the SAC of CA
    Slightly larger than the Crosstrek's Method and KO2s hehe
    Trek is running 235/75/15
  30. May 6, 2021 at 1:05 PM
    stupidchicken03
    Thomas
    In the SAC of CA
    whole new truck now! Might even wash it today haha
    5N0W808, Jack McCarthy and KK6PD like this.
