Checking Transmission Temps
Discussion in 'General Tundra Discussion' started by tacomawv, Aug 11, 2020.
  1. Aug 11, 2020 at 5:07 PM
    tacomawv
    tacomawv [OP] New Member
    Richard
    With all of this talk about transmissions running hot I want to check my temps. What do you guys recommend to check the temps. Are the blue tooth OBD 2 readers good for this. I tow 90% of the time with my truck. I have a SR with a 4.6 so I do not have a external cooler just like the new Tundra's.
    Thanks
  2. Aug 11, 2020 at 5:55 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    Blue Thunder and Johnders2586 like this.
  3. Aug 11, 2020 at 6:52 PM
    Blue Thunder
    Washington
    This is what I have too. Love it. Had it for about a decade now and just keep moving it from vehicle to vehicle. You can program it to monitor the torque converter as well, so can see it and the pan temps.
  4. Aug 11, 2020 at 7:24 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I use my iPhone with an app called OBD Fusion connected via Bluetooth to Veepeak ODB dongle.
    The dashboard was created with the help and advice from members of this forum. Just search “PID” and you’ll find the thread.
  5. Aug 11, 2020 at 8:49 PM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    I also use OBD Fusion app on my phone, and OBD 2 reader. Works great via Bluetooth. If you go this route make sure the OBD 2 reader is compatible with your phone (Android or Apple).
  6. Aug 12, 2020 at 3:51 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    I have a Kenwood DMX906S HU in my 2019 with the OBD2 interface and it can display Trans Temps.
    blcooper7 and Jtundra81 like this.
  7. Aug 25, 2020 at 12:02 PM
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    Hmmm torn between a scanguage and the obd fusion app route. Pros and cons?
  8. Aug 25, 2020 at 1:28 PM
    mountainpete
    ScanGauge = reliable, old school display. Max 4 data points at a time. Needs to be mounted and run a cable to ODB port. Doesn't draw from battery when engine off.
    OBD Fusion = iPhone display, can have many data points and multiple "dashboards", requires a wireless OBD reader (which does draw from the battery still when engine is off), requires a phone mount to be useful.
    I have had both. OBD Fusion gives me more for less effort and I like having gauges vs data points.
    meyer and pickeledpigsfeet like this.
  9. Aug 25, 2020 at 1:37 PM
    Hartsy8
    Max
    2020 MGM 1794
    Thanks for the information, this helps. Is the draw on the battery significant? I would assume not. It seems like many folks on here run it just fine? Thanks again!
  10. Aug 25, 2020 at 1:56 PM
    timsp8
    NY
    Price too. Scan gauge is about $150. You can get OBD readers that connect to your phone for $30 or so.
    BravoDeltaRomeo likes this.
  11. Aug 25, 2020 at 2:15 PM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    I think battery draw is virtually insignificant, I have left the OBD2 reader plugged into the port for days with no noticeable changes to the truck. Of course it's probably prudent to remove it after you have finished your investigating for the trip. I just keep it in the center counsel, only takes a moment to plug it in and turn on phone app, good to go.
  12. Aug 25, 2020 at 2:48 PM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    If you're thinking about doing any engine tune stuff eventually, a Bullydog tuner will monitor trans, coolant, intake temp, etc, etc, also.
    Hartsy8 likes this.
  13. Aug 25, 2020 at 3:25 PM
    mountainpete
    Not significant, but it is one of the negatives of a bluetooth based OBD2 reader. Pull it out if you're leaving the truck at the airport for two weeks to be safe, especially if the temps are below freezing.
  14. Aug 25, 2020 at 3:36 PM
    Hartsy8
    Max
    2020 MGM 1794
    You are talking my language now haha. Which OBD reader would you suggest
    CaptCraig likes this.
  15. Aug 25, 2020 at 4:26 PM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    I have the BAFX Products Bluetooth OBD2 Reader, about $23.00 at Amazon. Then download the OBD Fusion App for your phone, the App is like $5.00 then you want to buy the optional package for your year truck about $10.00. That will give you access to monitor almost anything.
    Just make sure you get Android or Apple compatible, depending on your phone.
  16. Aug 25, 2020 at 5:00 PM
    Professional Hand Model
    Hand Protectors
    Just started using the BaFx OBD about a few weeks ago and can say its impressive. Never used a reader before, but I think this one is probably the best one regardless of price under $300.
    It has 17,468 reviews and most are glowing. It doesn’t do everything, but it does a lot.
    $23 plus $5 for the better Torque Pro App. Hooked it up to an old Android Device.
    I feel sorry for you guys with the excessive trans temps. The 1st Gen barely breaks 170° on a hot 95° day in stop and go traffic. :D
    Dragracer_Art likes this.
  17. Aug 25, 2020 at 5:19 PM
    mountainpete
    I went with Veepeak BLE+ Bluetooth 4.0. Works great with an iPhone.
    Jtundra81 likes this.
  18. Aug 25, 2020 at 5:35 PM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Since adding the cooler to my '20, pan temps settle in the mid-170's now instead of 220's.
  19. Aug 25, 2020 at 5:36 PM
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    I use this setup with my android and its flawless.
    Cant beat it for the price.
  20. Aug 25, 2020 at 5:49 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    I have used OBD Fusion in the past and I like it. Just added a Scangauge II today since I find it much simpler to leave that installed all the time than grab & mount my phone/iPad, connect to the OBD2 WiFi dongle (guess bluetooth version would fix this part), run the app, etc. On longer trips I will probably run both since the iPad is going to be mounted anyway for Waze/Gaia (and I installed an OBD splitter today as well).
  21. Aug 25, 2020 at 6:09 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I have a ScanGaugeII I bought in 2006. I just sent it off for a firmware update today, but the wireless one discussed above is so inexpensive I went ahead and ordered one. I didn't like the idea of mounting my ScanGaugeII if I wanted to monitor the tranny temps.
  22. Aug 25, 2020 at 7:05 PM
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    Yeah , I would remove it , I always do whenever I am done with my trip and keep it in center console , I had a GMC envoy prior of the tundra , went on a camping trip and forgot to remove it , it drained battery overnight
  23. Aug 25, 2020 at 7:08 PM
    Lyuluck
    Lyuluck New Member
    luck
    App of Smart phone is wonderful
  24. Apr 11, 2021 at 11:33 PM
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
    Where are you all mounting your scan gauges at on your 3rd gen?
  25. Apr 12, 2021 at 3:50 AM
    timsp8
    NY
    On top of the steering column with Velcro.
  26. Apr 12, 2021 at 4:14 PM
    marshmellow
    marshmellow New Member
    San Diego
    2021 Toyota Tundra CM
    I got the OBD link MX+. Works well enough for me.
    Rica25 likes this.
