Checking the oil level is an exercise in futility
Discussion in '3rd Gen Tundras (2022+)' started by F150 blowz, Nov 5, 2023.
  1. Nov 5, 2023 at 2:50 PM
    F150 blowz
    F150 blowz [OP] New Member
    Michigan
    2023 CM SR 4x4
    I changed my oil yesterday. Go to check the level on the dipstick and this appears to be one of those designs where it is next to impossible to get an accurate oil read. The oil comes out smeared all over the dipstick and you can’t tell what the level is. Rant off.
    Is everybody having this issue or am I a dumbass?
    This is a 2023 gen 3.
    Tom, Carolina Peej, DFS and 1 other person like this.
  2. Nov 5, 2023 at 5:05 PM
    kirkb
    kirkb Tired New Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    Yes it's a pita. I gave up doing the old school method(pull, wipe, insert, pull, look) and instead just let it sit for 15 min then pulled and looked.
    https://www.tundras.com/threads/checking-oil-level.131343/#post-3341213
    Tom and Mattedfred like this.
  3. Nov 5, 2023 at 5:19 PM
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    Look closely at both sides. One side will typically be smeared to the point you can not get a reading off it, while the other typically has a defined upper limit where the oil stops and you can take your reading. At least this has been my experience. The 0w-20 doesn't make it any easier to read, that is for sure.
    Kap1 likes this.
  4. Nov 6, 2023 at 2:20 AM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Past f150 I had to use a 3 step just to get up high enough to reach it. At least we can grab it without any assistance But just let it sit for alittle and the reading gets alittle better.
  5. Nov 6, 2023 at 7:05 AM
    Tom976
    Tom976 New Member
    Tom
    I used a piece of steel wool (and even emery cloth) to rough up the one side of the lower few inches of the dip stick.
    This allowed the oil to have a little more "grip" when it was being pulled out.
    Did this by putting the dipstick on the flat edge of a vice and went back and forth putting horizontal marks on the dipstick.
    Nothing crazy deep but it seemed to work better.
    Now after a little use the oil will get easier to read as it darkens up.
    FrenchToasty likes this.
  6. Nov 6, 2023 at 9:47 AM
    iforceAZ
    iforceAZ New Member
    Just changed my oil for the first time. It is a pain in the butt. I measured what came out and it exactly filled up two gallon milk jugs.
    Only way I found to measure reliably is to let it sit overnight or for several hours and look on dipstick on first pull out. If you wipe and go in and out then it smears.
    kirkb likes this.
  7. Nov 7, 2023 at 3:11 AM
    F150 blowz
    Michigan
    2023 CM SR 4x4
    Interesting, did you fill it up with 8 quarts then or just do the 7.7?
  8. Nov 7, 2023 at 5:56 AM
    iforceAZ
    iforceAZ New Member
    Tried my best to estimate 7.7 quarts. But honestly, from here out I'm just dumping in 8 quarts. That extra 0.3 quarts is equal to 1.2 Cups. I'm fine with that.
    Johnsonman likes this.
  9. Dec 3, 2023 at 6:30 PM
    smileytn1
    smileytn1 New Member
    Nope your not a da Toyota is for cheeping out and designing such a pos. i been a truck driver big and little rigs and farmed with all types equipment and at least if they want to make all those stupid turns they could have designed a dipstick like the old speedometer cable types used in road tractors and Detroit diesels shame on you Toyota for the price WE DESERVE MORE
    Eagleye, Tom976 and TundraDan723 like this.
