Checking brake fluid
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rustyscrew, Jul 6, 2019.
  1. Jul 6, 2019 at 8:02 AM
    Rustyscrew
    Rustyscrew [OP] New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    Anyone else find the brake res. a little more challenging to check and see what the fluid level is at? I find the its not dark enough to see the level is on the side and can't see in the top either too easily.
  2. Apr 7, 2020 at 4:25 PM
    manhster
    manhster New Member
    Richmond, VA
    '17 Black CM 4x4 Ltd TRD OR
    I just got a used 17 CM Ltd 4x4(49k miles) and brakes work fine. Just looking at the engine and noticed the brake fluid reservoir. Looks empty or not? can't tell. Did you figure this out?
  3. Apr 7, 2020 at 4:30 PM
    15whtrd
    15whtrd Mr. Blonde
    Try shining a flashlight behind it.
    NewImprovedRon, rodm1 and JohnLakeman like this.
  4. Apr 9, 2020 at 8:52 AM
    rodm1
    rodm1 New Member
    Flashlight works grate.
    15whtrd likes this.
