Check these out
Discussion in 'Lighting' started by davesnothere, Aug 24, 2016.
  1. Aug 24, 2016 at 4:38 PM
    davesnothere
    davesnothere [OP] New Member
    Dave
    Down South, Texas
    2016 Tundra Limited 4x4 5.7ffv
    Pro Comp stage 2 6" lift- 20" XD Rockstars- 35" pro comp a/t sport- Hypertech Interceptor- 7" BA Muffler- 4.88 Yukon gears
    Just ordered these off Amazon, they replace your door light and project the emblem.
    Hammerhead and Black Wolf like this.
  2. Aug 24, 2016 at 4:39 PM
    davesnothere
    Dave
    Down South, Texas
    But as you see you also keep light, forgot to add that
  3. Aug 26, 2016 at 11:13 AM
    davesnothere
    Dave
    Down South, Texas
    Have to say how disappointed I am that Toyota took out the courtesy lights off the doors. I can understand takin them off stock but off limited too? Cmon Toyota, so needless to say I don't think I will be able to use these
  4. Aug 26, 2016 at 11:26 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    I've seen those before, pretty cool. I may get myself a set for my birthday.
    Is that a picture of one you've installed? How easy was it? Did you have to remove the door?
  5. Aug 26, 2016 at 11:54 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    You can probably tap into the footwell light on the drivers side which comes on when you open the door
    NewImprovedRon likes this.
  6. Aug 26, 2016 at 2:07 PM
    davesnothere
    Dave
    Down South, Texas
    Was thinkin that too, there's still a spot to put lights but I didn't want to mess with takin the panel off. The only other option is to get the ones that stick on the side of the door pocket and that just looks ghetto and would probably get knocked off
  7. Jan 5, 2017 at 3:22 PM
    Tundra.v2
    Tundra.v2 New Member
    07&15 Tundras
    Not hard at all, I recommend you guys doing it. Taking off panel getting into wiring system also adding light in the back seats. Not hard at all, did all this within 4hrs for both doors also lights in the back
  8. Jan 5, 2017 at 3:34 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Very nice job on the lighting!! I like it. I have all the stuff to install the footwell lights but just haven't done it yet. In fact I bought a roll of colored light strip that are controlled via remote. I think I'll install those. They will do all colors including white.
    Tundra.v2[QUOTED] likes this.
  9. Jan 5, 2017 at 5:11 PM
    davesnothere
    Dave
    Down South, Texas
    Did you pop off that little knock out piece? Which wires did you tap into? Are those the same style lights
    / do they just sit in there flush? Nice job
  10. Jan 5, 2017 at 5:22 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I likey and want but no can do? SR5?
  11. Jan 5, 2017 at 5:38 PM
    NurEye
    NurEye New Member
    2008 Tundra SR5
    Very nice guys. Where'd you find these lights at? What did you search on Amazon?
