Check Engine Light Won't Turn Off
Discussion in '2nd Gen Tundras (2007-2013)' started by myt1, Jan 3, 2022.
  1. Jan 3, 2022 at 6:16 PM
    myt1
    myt1 [OP] New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    I don't remember which code number it was, but it was the one that comes on when you don't turn the gas cap until it clicks after filling with gas. I must've gotten distracted.
    The person at O'Reilly's that helped me said that the light would go off after a day or so.
    It has been 3 days and I'm wondering if I need to have the code cleared.
    I'm guessing they aren't allowed to clear codes at O'Reilly's.
    Thanks.
  2. Jan 3, 2022 at 6:27 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
  3. Jan 3, 2022 at 6:30 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    I once bought a defective new “oem” cap from eBay and it didn’t work. I then bought aftermarket from Orielly’s. Light turned off on its own. When you correct the condition the light should go off - depending on the condition. Easy to clear with a cheap $20 reader from the inter webs.
  4. Jan 3, 2022 at 6:34 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    You can also try disconnecting negative battery terminal for an hour or so
  5. Jan 3, 2022 at 6:38 PM
    Depends on if it's a pending or history code.
  6. Jan 3, 2022 at 6:43 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    I don’t believe the light will come on if it’s pending. But maybe it does. I think it could take a few cycles to clear for the more in depth issues that require several cycles. But I usually clear them with scanner.
  7. Jan 3, 2022 at 10:08 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Spend $35 and get a code reader to read the code, then post it here. The $35 code reader should also be able to clear codes.
    myt1[OP] likes this.
  8. Jan 8, 2022 at 10:40 AM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    If its not turning off and its the "Gas cap" one make sure its clean, if that doesn't work go ahead replace cap. If it still doesn't work then you have a small evap leak somewhere in your system.
  9. Jan 8, 2022 at 11:23 AM
    Ericsopa
    Ericsopa Old man and the sea
    I had to clear the code the one time it happened to me.
  10. Jan 8, 2022 at 11:55 AM
    White Falcon
    White Falcon New Member
    2007 Tan, TRD,, 4.7
    None
    You tube has instructions on how to turn off, Easy.
  11. Jan 8, 2022 at 12:18 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    This. You can buy them at walmart and Amazon. No excuse really 25 years after OBD2 became standard to not have a $35 code reader and still be posting threads asking other people what your check engine light is for. We cant really help you with the information provided.
    Depending on your driving it can take longer than 3 days to clear a fault code assuming you have repaired the fault condition. As others have said you can disconnect the battery to clear it.
  12. Jan 8, 2022 at 1:14 PM
    CMikeB
    CMikeB New Member
    When it happened to me, the gas station was so noisy combined with my trashed hearing, I couldn't hear the click. Third day, it was gone. Still seeing "drivers" filling up with engine running too.o_O
  13. Jan 8, 2022 at 1:41 PM
    Coastie Dan
    Coastie Dan New Member
    2016 TRD Pro
    Skid plates, tow package, air bags in rear
    When my wife is on board I have to keep the engine running occasionally as she is on her air machine and it's charging. Easier to fill with it running than hear some gawd awful noise from the passenger seat. :argue:
    CMikeB likes this.
  14. Jan 8, 2022 at 1:45 PM
    timsp8
    NY
    This’ll fix it.
    Silverghost likes this.
  15. Jan 8, 2022 at 2:50 PM
    Coastie Dan
    2016 TRD Pro
    Just sent for a new gas cap since it's so cheap. Thanks everyone for all of your input.
  16. Jan 8, 2022 at 3:16 PM
    myt1
    Richard
    Scottsdale, AZ
    I ordered a scanner, but before it arrived the light went out on its own...of course it did.
    It took about 4-5 days of intermittent short trip driving and it finally went out.
