Check engine light on and traction control off 4.6 L
Discussion in '2.5 Gen Tundras (2014-2021)' started by adydeo99, Oct 13, 2021.
  1. Oct 13, 2021 at 4:59 AM
    adydeo99
    adydeo99 [OP] New Member
    2014 Red Tundra 4.6
    Hi guys,
    just in need of some help here. The check engine light is on and traction control is off and I’ve tried resetting it many times by removing the battery cable. The lights come off for a few weeks then it comes back on again. Also what’s weird is the gas mileage improves with the reset and I gain more driving mileage which I don’t understand. If I can get some advice I would really appreciate it.
  2. Oct 13, 2021 at 5:09 AM
    Hostage81
    Hostage81 New Member
    SMJ
    Planet Earth
    2021 Trd Off Road
    Stock
    Abs sensor perhaps ?
    Any time you disconnect battery, the mpg is reset and gives false high reading till it learns your driving patterns and then gives accurate mpg.
  3. Oct 13, 2021 at 5:24 AM
    nmjameswilson
    nmjameswilson New Member
    James
    Kansas City
    2021 Limited Nightshade Double Cab
    My 2008 used to do that when my mass air sensor had dust on it and needed to be cleaned. I had an after market intake so it was a problem. Maybe that could be it if it is running bad too.
    Every time you disconnect the battery cable it resets the miles to empty way higher than what it actually is. It will reset once it determines your driving habits.
