Check engine light codes P0365 and P0102
Discussion in '2nd Gen Tundras (2007-2013)' started by Mojo55, Oct 14, 2021.
  1. Oct 14, 2021 at 3:45 PM
    Mojo55
    Mojo55 [OP] New Member
    Lance
    2011 Tundra base
    I'm not sure exactly sure where this should go so moderators i apologize in advance if this is the wrong spot. I have 2011 Tundra base with the 4.6 V8, 128,000 and recently had a check engine light come on ,P0365-camshaft position sensor B circuit bank 1.I replaced the sensor and few days later my check engine light came on again, same code P0365 and P0102, Mass or volume air flow sensor A circuit low. I cleared the codes cleaned the air flow sensor etc... drove for a day or so- check engine light again with the same codes. So i replaced the air flow sensor and drove about 25+ miles no issues..... until today while idling in the parking lot my check engine light comes on.......same two codes ... ( my buddy loaned me his code reader FYI and have kept it with) I dont know what else to do and would appreciate it if someone can steer me in the right direction etc.. FYI I'm not a mechanic by know means I'm actually a tired respiratory therapist lol
    Any help would be greatly appreciated.
  2. Oct 14, 2021 at 4:39 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  3. Oct 15, 2021 at 6:58 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    When you got this codes, what debugging steps did you take?
    These two codes together would have me looking for rodent damage on the wiring harness. It may help to have the truck running and idling with a scan tool showing the live data for the MAF sensor, then as you inspect the wiring if the reading jumps or drops to zero, you know you're in the right area where the damage is.
  4. Oct 15, 2021 at 7:56 AM
    Mojo55
    Lance
    2011 Tundra base
    Thanks fellas for you input!
  5. Oct 16, 2021 at 9:41 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    …Yeah - and you can also rule in or out the camshaft sensor by switching it with the one next to it, and see if the code jumps to other circuit.
