Check Engine Light 2008
Discussion in '2nd Gen Tundras (2007-2013)' started by Eddy20, Feb 4, 2025.
  1. Feb 4, 2025 at 9:54 AM
    Eddy20
    Eddy20 [OP] New Member
    Been reading about CEL issue and guessing some sensor, truck performs and runs fine. 150,000 on the clock, is it worth disconnecting the battery cable to re-set or just take it to a mechanic? I'm not a mechanic and don't work on my vehicles.
  2. Feb 4, 2025 at 10:54 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Could be something as simple as a bad gas cap.
    disconnect battery and reset. If it comes back drive to a autozone or similar and they can scan for and codes. Report back with any codes.
    Lifer likes this.
  3. Feb 4, 2025 at 11:43 AM
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    Mine at 136K is the catalytic at least that is the code it shows. X2 advice above.
