Check Engine / Cats
Discussion in '2.5 Gen Tundras (2014-2021)' started by Deans 2021, May 3, 2024.
  1. May 3, 2024 at 6:06 PM
    Deans 2021
    Deans 2021 [OP] New Member
    Thomas
    Well my aftermarket cats did throw a code. The MAGNAFLOWS were put on by the dealer, because it sat for 8 months waiting for OEM's. Its been working good for 6K miles, towing a trailer and general run around activities. Went to AutoZone and had them scan it. The report showed the cat needing replacement. I've only got 18K on the truck and wondering is that covered under my 3year 36month warranty ? Any thoughts are helpful !
  2. May 3, 2024 at 6:14 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    I would just get an OBDlink MX+ or similar device for reading codes using your phone. Then just drive around and clear the codes when they come up, depending on the codes and frequency of them you can put in mini cats that will usually prevent cat codes.
    Now since the dealer put them on if it’s very recurring and depending on the codes I would take it back and have them replace with OEM.
    Mdl likes this.
  3. May 4, 2024 at 5:53 PM
    Deans 2021
    Thomas
    I took it to the dealer to have them check it out. We'll see..
  4. May 4, 2024 at 7:46 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Whats a mini cat?
  5. May 4, 2024 at 7:54 PM
    NoMoreGreen
    NoMoreGreen New Member
    Robert
    2020 Tundra
    I waited a year for my OEM cats in 21-22 after they were stolen........
    ETA: sorry you are going through this. I bet someone on the performance side of the house knows a non OEM way to fix this, or see if you can get OEM replacements paid for by someone else.
  6. May 4, 2024 at 8:31 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Spd performance downpipes and done
    cavalry bear, texasrho83, Mdl and 2 others like this.
  7. May 5, 2024 at 12:17 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    They are small catalytic converters that plug into the o2 sensor hole then the o2 sensor plugs into them. This is intended to make the o2 sensor believe the catalytic converter system is functioning correctly. They are usually 50-75$ a piece. This is commonly used for systems with high flow cats or no cats, where tuning cannot remove the CEL errors. *obviously for offroad use only in Mexico*
  8. May 6, 2024 at 5:26 AM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    I’ve been looking into this option and very interested, but does the larger pipe diameter cause any low end torque issues?
  9. May 6, 2024 at 5:35 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Nope
  10. May 10, 2024 at 3:41 PM
    Deans 2021
    Thomas
    Update: The dealer suggested contacting the insurance company for a supplement to the original claim. I was nervous when I called. Geico was more happy to reopen it and sent the adjuster to the dealer. They approved the total replacement to OEM cats. The dealer isn't having any problems getting them, a couple of days. So for info purposes I posted this if anyone else has issues with their aftermarket cats (dealer installed). Don't hesitate to call if yours fail.
    TacomaTRD4x402 and texasrho83 like this.
  11. May 10, 2024 at 3:59 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Sound a lot like defoulers
  12. May 10, 2024 at 5:27 PM
    yakeng
    How much is the dealer quoting for the cats?
  13. May 10, 2024 at 5:47 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
  14. May 10, 2024 at 5:55 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Either way, they don’t work, regardless of the country your off-roading in
  15. May 10, 2024 at 6:00 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Works for me, currently using with my long tube headers.
  16. May 10, 2024 at 6:03 PM
    FrenchToasty
    Mo
    Bone stock
    With or without kitties?
    My cats were stolen, so I had to put in test pipes, I still get a cel everyday
  17. May 10, 2024 at 6:12 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    I have 2 high flow 200 cell cats. Which when running as is would get multiple types of CELs daily. Using the large mini cats no more CEL. Smaller engines can run no cats and use the small mini cats for rear O2s, larger engines need the large ones at least. Guys will stack large and small and/or a 90d bend when going catless type setups.
  18. May 10, 2024 at 6:16 PM
    FrenchToasty
    Mo
    Bone stock
    Yeah I only had so much room to stack……. On my small engine
  19. May 10, 2024 at 7:02 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    Which code #? If it's an after cat code i would try spark plug defoulers. They are cheap and easy to install. Worked on my old Nissan but that was an older vehicle. If you are in an emissions testing location you will probably fail for using them though.
  20. May 11, 2024 at 7:01 PM
    Deans 2021
    Thomas
    I haven't seen the paperwork yet. But when I settle everything I will let ya know.
  21. May 26, 2024 at 8:48 PM
    Deans 2021
    Thomas
    The dealer charged my insurance company 5988.12. The truck seems peppier and I am happy with the results.
