Check Eng./ Maint Req'd Lights at the same time . . . need asst
Discussion in '1st Gen Tundras (2000-2006)' started by HBTundra, Jun 9, 2022.
  1. Jun 9, 2022 at 6:24 PM
    HBTundra
    HBTundra [OP] New Member
    2006 DC 2wd
    2006 DC w/ only 67K .
    Check Engine / Maintenance Required light's came on at the same time.
    What's the 'Go-To' for a decent Coder Reader for the Layman. or 'Lame-Man'. LOL
    TIA.
  2. Jun 9, 2022 at 6:38 PM
    Hey stranger.
    Go to local auto parts store.
    They scan for free and give a print out in most cases.
    Then focus on getting your own later.
  3. Jun 9, 2022 at 6:43 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Oil change reminder, and probably the gas cap……
    Hit me up if your in the south west soon!
    MEWaters, HBTundra[OP] and shifty` like this.
  4. Jun 9, 2022 at 6:59 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    A lot of members here like the scanguage 2 which also provides mpg in addition to the code along with some custom PIDs from toyota. $
    The wireless bluetooth OBD2 adapter is another one where you can run the Torque app on your andriod phone is also popular. $
    Myself, I have an Actron CPxxx that can take multiple data points over time and later import it into excel. More $$$
    HBTundra[QUOTED][OP] likes this.
  5. Jun 9, 2022 at 8:04 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Maint reqd comes on every 5k miles as far as I know. Check engine light could be checked at a parts store or just get a basic $20 code reader.
    HBTundra[OP] likes this.
  6. Jun 9, 2022 at 8:42 PM
    HBTundra
    2006 DC 2wd
    Thanks guys.
    I re-set the maint-reqd, and that went away . . . it was due.
    Check engine still on . . . will report back.
    Appreciate the 411.
    FrenchToasty likes this.
  7. Jun 10, 2022 at 5:31 AM
    If engine is running fine and gas cap is torqued on, and this came out of the blue, I'm going with something emissions related, O2 or maybe EVAP.
    But I've been wrong many times before.
  8. Jun 10, 2022 at 8:53 AM
    HBTundra
    2006 DC 2wd
    Haven't had a chance to get the code(s) yet, will do this afternoon.
    Gas cap is tight, and 'Maint Reqd' light still off.
    Check Engine light still on.
    On a cold start this morning it made an unusual sound for about 5-10 seconds . . . hard to describe , but almost sounded like when those cars with the air suspension start up and you hear that that low-tone air compressor / pump sound. It went away quickly.
    Truck runs fine, nothing changed since light(s) came on. Gauges all read normal.
    Thanks again and I'll report back soon.
  9. Jun 10, 2022 at 9:43 AM
    Hmmm... SAIP? But most people describe that as more of a whine/whistle than anything. You do have an '06, so it would definitely have SAIP. Truck would otherwise run fine, with noise at startup, when SAIP fires up.
    rock climber and FrenchToasty like this.
  10. Jun 10, 2022 at 11:51 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
  11. Jun 10, 2022 at 2:02 PM
    HBTundra
    2006 DC 2wd
    DAMNIT !
    I'm in CA, so the By-Pass kit is a no-go for Me.
    So what's the deal, ? . . . can I run it for a while till I can pony up the dough to have it fixed ? . . . or will it take a crap on me and leave me stranded ?
    Thanks for all the help Peeps.
  12. Jun 10, 2022 at 2:52 PM
    Shouldn't leave you stranded. Someone else on here lives in CA and used the bypass, I thought. As long as you don't have visual inspections? The unit just mimics the input/output you'd see w/SAIP running.
    HBTundra[OP] and FrenchToasty like this.
  13. Jun 10, 2022 at 2:56 PM
    FrenchToasty
    Mo
    Bone stock
    Even with a visual, I was able to hide it decently, although I’m not sure how well the look over the engine bay
  14. Jun 10, 2022 at 3:06 PM
    rock climber
    What they said. Run it in CA.
  15. Jun 10, 2022 at 4:21 PM
    HBTundra
    2006 DC 2wd
    Interesting . . . thanks for all the good feedback.
    Guess I've got some homework to do.
    Start by seeing if Hewitt will even sell / ship it to a CA resident.
    May have to enlist the help of some of my AZ friends.
  16. Jun 13, 2022 at 6:39 AM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    In California, at least my county, they do a pretty thorough visual inspection. I guess it depends on how easy it is to hide the bypass, and how clued in the inspector is.
  17. Jun 13, 2022 at 6:59 AM
    HBTundra
    2006 DC 2wd
    The guy I've taken my trucks too isn't that thorough, heck I don't even know if he even pops the hood LOL.
    If I get dinged, I guess I'll have to pony up the dough, but the bypass kit should get me through for a while, I don't wanna burn out the air pressure sensor(s) in there or deal with the 'Limp Mode' fiasco.
    My registrations isn't due till December and hopefully they won't require a smog cert this time around.
    chunk[QUOTED] likes this.
  18. Jun 13, 2022 at 10:22 AM
    rock climber
    It's pretty easy to make it look like a factory install. Unless the inspector is specifically looking for the bypass I think they'd have a hard time seeing it.
    logmein and HBTundra[OP] like this.
  19. Jun 13, 2022 at 11:00 AM
    HBTundra
    2006 DC 2wd
    I spoke with the person at Hewitt earlier, he was saying that he's sold these kits to customers who've replaced their entire SAIS system 2 or 3 times, and were fed up with it. It's a shame Toyota didn't fix the problem, or at least upgrade the materials used in the failing parts. Seems like a whole lot of nonsense just to pre-heat the cat for 30 seconds.
  20. Jun 13, 2022 at 11:29 AM
    FrenchToasty
    Mo
    Bone stock
    Also
    Slyfox on t4r.org makes a similar kit for cheaper, that’s who my bypass is done thru
  21. Jun 13, 2022 at 11:52 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    This will 100% leave you stranded and in limp mode.
    Until you fix it, always have a code reader and be prepared to clear the code when it enters limp mode.
    My Sequoia has gone into limp mode even with the Hewitt, but that was when it was below freezing out.
    I’ll link my thread, one sec.
    https://www.tundras.com/threads/stranded-in-san-diego-no-power-aip-help.98061/
  22. Jun 13, 2022 at 11:55 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    My plan to pass smog, is make sure the vehicle is warm before taking it in, then Disconnecting the Hewitt. It only uses the SAIP when the engine is cold. I’ll have to test this out in January when it’s do for smog.
  23. Jun 14, 2022 at 6:13 AM
    I think "leave you stranded" is arguable here.
    If you find yourself in limp mode, in theory, you should be able to pop the neg cable off for 10 mins, fire up and go, or if you've a reader, clear codes as you mentioned. Delayed by 15 minutes, yes. Stranded, no.
    I'm open to being wrong about that with 1GT trucks, but the "poor bastard ECU reset" has served me well with other vehicles in the past.
  24. Jun 15, 2022 at 12:24 PM
    HBTundra
    2006 DC 2wd
    Well, I ordered the Gen 2 kit from Hewitt and it will be here Friday.
    Sounds like taking off the front wheels/tires gives a bit more access to install the blocking plates.
    I'm a little sketched on removing the glove box as I suck at removing interior trim stuff.
    Probably gonna have my buddy come over and make sure I'm tapping into the right wire(s) at the ECM, along with my bad vision, I'm color blind as well, and with my luck I'll splice into the wrong wire and cause even more problems. LOL.
    Soldering is no problem, it's the soldering of the RIGHT WIRE that gets me. :rofl:
  25. Jun 15, 2022 at 12:57 PM
    rock climber
    I haven't watched the video in a while, but I didn't have solder anything or remove the glove box.
  26. Jun 15, 2022 at 3:10 PM
    HBTundra
    2006 DC 2wd
    According to their website installation instructions, the 'Gen 2 Version' requires tapping into the ECM.
    It doesn't tie into into the starter relay or MAF like the other model for our Gen 1 trucks.
    It's a little different set up where you remove the Air Injection Driver (AID) and replace it with their module.
    It also ties into the Vacuum Switching Valve (VSV) on the passenger side near the intake manifold.
    Then you run the loom through the firewall and splice into 3 specific wires at the ECM.
    I guess the Gen 2 version emulates the operation of the SAIS and will also show it as 'complete / ready' when on a scanner.
    This is all new to me, just been reading up and trying to understand all this SAIS mess a bit more.
    shifty` likes this.
  27. Jun 16, 2022 at 12:47 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    I hear you, but road trip, no tools, The 405. Can’t get over 25mph at 11pm.
    That’s pretty stranded lol.
  28. Jun 16, 2022 at 12:52 PM
    Oh, you're not wrong! My wife liked Death Cab for Cutie way back, before they ditched their lo-fi sound for over-produced polished garbage sound. I always chuckled at how much contempt they have for the freeways over there, with a couple of pretty pointed jabs at the 405 specifically. "Garbage cans comprise the medians of freeways, always creeping ... Even when the population's sleeping..." and so on.
    I'm fortunate my time in CA was limited to a 2-year stint in San Diego during the late 80s, and occasional trips to El Segundo before we closed our site there, and SFO/MTV for two sites we've got there. I Uber/Lyft while there. As much as people make fun of ATL traffic, CA is 10x worse to me, and SFO is a skid mark in the Bay Area's trousers.
    Diablo169[QUOTED] likes this.
  29. Jun 16, 2022 at 12:59 PM
    chunk
    chunk New Member
    The worst stretch of the 405 in Southern Calif., I think, might be the piece over the Sepulveda pass between the SFV and Westwood. I had a G/F who lived in Westwood and went to UCLA some years ago, I would take a motorcycle to see her so I could split lanes. It's congested pretty much any time or day of the week. Motorcycles and e bikes are a great way to navigate the traffic here.
  30. Jun 16, 2022 at 8:30 PM
    HBTundra
    2006 DC 2wd
    . . . alright, ( Disclaimer 5 beers deep post Hewitt install so don't nail me to the cross over my sloppy re-cap).
    Everything went well, the plug & play portion was a no brainer.
    Pushing the 3 wires through the firewall was a challenge.
    I enlisted help / took the passenger side kick-panel off, and what worked best was to take a semi-rigged piece of stainless steel wire to push in from the motor bay to the inside where I could see it . . . . then we bent the stainless wire, and taped the 3 Hewlitt wires to it and used it as a 'fish tape' .
    Worked perfectly.
    Pulling the plug on the factory harness was easy, so was slightly scoring the electrical tape to reveal the wires . . . . stripping a 'running section' of the wire is, shall I say 'delicate' at the very least. . . identifying the correct colored wire etc. semi sketchy (especially being color blind) . . . . then soldering into them with the Hewlitt kit was standard.
    I put liquid electrical tape after the solder, then electrical tape over that, and bundled it all up.
    The block-off plates on mine were fairly easy on the passenger side. I sprayed the connection prior with WD 40 and was able to crack them with some monkeying around. The drivers side was a PITA . . . I ended up taking off the front tire/wheel and removing that rubber curtain to get at it.
    Button'd everything up, fired it up, and she lit off like a roman candle without codes !
    Took her for a spin and clipped 90 MPH on PCH, just to say 'F-It' !!!!
    Hell Yeah !
    2006Tundra, aRabidLunatic and shifty` like this.
