Chassis grease - Lithium or Synthetic?
Discussion in '1st Gen Tundras (2000-2006)' started by F1reheart, Aug 29, 2017.
  1. Aug 29, 2017 at 2:09 PM
    F1reheart
    F1reheart [OP] Love my Tundra
    2003 SR5 4.7
    hi guys!
    My new Haynes manual tells me to get NLGI 2 lithium-based grease for lubing my u-joints, etc. However, I also see NLGI 2 synthetic grease. Which one is better for my truck? Can I add synthetic to old lithium?
    Thoughts and suggestions?
    Thanks!
    Pucks18 likes this.
  2. Aug 29, 2017 at 2:15 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    I use Mobil 1 synthetic. In fact, I just got done lubing the driveshaft this morning.
  3. Aug 29, 2017 at 2:50 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    On a serious note, how often should this be done?
  4. Aug 29, 2017 at 3:18 PM
    Either choice is good. As far as when....Depends on a few things for instance do you wheel a lot in the mud/water muck? Do like me...crawl underneath and do a visual inspection. If all the joints look dry....lube time.
  5. Aug 29, 2017 at 4:31 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    It's sad and a little amazing that the 2 year "Toyota care" doesn't include grease or air filters.
    BTBAKER and Black Wolf like this.
  6. Aug 29, 2017 at 4:35 PM
    Agree, but doing your own lube job gets you underneath your Tundra. Forces you to do a good visual over all inspection yourself that the dealer may miss.
    gosolo[QUOTED] likes this.
  7. Aug 29, 2017 at 4:41 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Absolutely agree, and I like doing it. However, not everyone is like us old guys and some put lots of miles on their trucks.
  8. Aug 29, 2017 at 4:42 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    It's a 5 minute job to get 4 out of the 5 grease fittings. One of the front drive shaft fitting took me over an hour once. It’s a giant pain in the neck to get the grease gun onto. I must have went through half a tube of grease the first time I attempted it.
    blizz86, Tundra Fan and Black Wolf like this.
  9. Aug 29, 2017 at 5:01 PM
    You need to get the special "fitting adapter" and remove transfer case skid. I went thru the same bs you did. I'll go to my storage unit and post the adapter you need. If I freaking remember. Getting ready to cook dinner for the kids. Old rust never sleeps......
  10. Aug 29, 2017 at 5:14 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    IMG_0783.jpg I use something like this but it's squared off and not sharp at the end
    Black Wolf likes this.
  11. Aug 29, 2017 at 5:22 PM
    Bingo!!!!!!.Saves me some freaking time. "Never use a dirty needle"....heh..heh. But you may still need the adapter. Pretty sure I went both routes..."Ahh....preemptive strike..yeah go ahead and go there". Gutter heads....hee...hee.hee.......shit...
    ep3Jee likes this.
  12. Aug 29, 2017 at 5:48 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Where do I go look to see what needs lubed? Any pics will help, or DIY.
    F1reheart[OP] likes this.
  13. Aug 29, 2017 at 6:04 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
  14. Aug 29, 2017 at 6:08 PM
    Les7311
    Thanks. I will crawl up. A grease gun is in order
  15. Aug 29, 2017 at 8:35 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I used to always buy two tubes of grease when my grease gun went out. Now I watch a video every time I change tubes. Lol
  16. Aug 30, 2017 at 4:14 AM
    F1reheart
    2003 SR5 4.7
    Thanks, great link - but the original question - is it OK to top off with synthetic if there was older lithium grease in there already?
  17. Aug 30, 2017 at 4:54 AM
    15whtrd
    15whtrd Mr. Blonde
    I went with Lucas red sticky and I think it is synthetic. Just flush out all of the old grease with the new grease. It makes a bit of a mess but at least you don't have two types of grease. Just pump until you see the new color grease coming out of the joints. And I do it at every oil change.
    Black Wolf, gosolo and Les7311 like this.
  18. Aug 30, 2017 at 5:00 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    The short answer is, yes, it's fine.
    You would be far more likely to be doing damage by disassembling and cleaning the parts than by either having no grease or several kinds of grease.
    The insertion of new grease pushes the old stuff out. After several cycles, you will have nearly exclusive contact on all the moving parts with the new lubricant.
    15whtrd likes this.
  19. Aug 30, 2017 at 8:06 AM
    Tundra_mike89
    Tundra_mike89 New Member
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Toytec boss coilovers Toytec shackles Total chaos uca's Method wheels Nitto ridge grapplers
    Only found 4 of 5 but o well. Greased with super lube synthetic grease. What I use on my total chaos uca's as well
  20. Aug 30, 2017 at 9:40 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    There are 3 on the rear shaft and 2 on the front. Are your UCAs uni ball or ball joint?
  21. Aug 30, 2017 at 9:47 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @Roman
    Would it be possible to post a picture of the grease zerk location schematic from the 2015 4x4 Tundra dealer service manual?
    '14-'18 should be similar, correct?
  22. Aug 30, 2017 at 9:48 AM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    I have one ball
  23. Aug 30, 2017 at 10:03 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
  24. Aug 30, 2017 at 10:38 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Should all be the same. :)
  25. Aug 30, 2017 at 10:49 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Thank you for this.
    Roman[QUOTED] and F1reheart[OP] like this.
  26. Aug 30, 2017 at 10:54 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Grease fitting 2 on the front shaft is a total chode
  27. Aug 30, 2017 at 11:00 AM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
  28. Sep 3, 2017 at 11:56 AM
    Les7311
    Purchased gun plus lithium from harbor freight and grease the drive shaft - 3 point areas. Also completed the SPC UCA.
    any other place to grease?
  29. Sep 3, 2017 at 12:01 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    You should have 2 more points to hit on the front driveshaft if you have 4 wheel drive.
  30. Sep 3, 2017 at 12:09 PM
    Les7311
    I do have 4x4. Let me go check thanks
    BlueFalconActual likes this.
