Charging system/Electrical
Discussion in '2.5 Gen Tundras (2014-2021)' started by JG1982, Mar 31, 2023.
  1. Mar 31, 2023 at 8:06 AM
    JG1982
    JG1982 [OP] New Member
    Jeff
    2015 SR5 5.7flex fuel Tundra
    Long post here, but I just got the X2 power AGM battery and my alternator voltage regulator recently tested bad. I’m ordering the GM diode that I’ve read is needed with AGM batteries, but when I replace alternator should I go with a high output/amp alternator or stock? Also should I upgrade big 3 wires? I have subs/amp installed, and Viper remote start/alarm.
  2. Mar 31, 2023 at 8:18 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    You might not "need" it, but I have the high output alternator. I would suggest doing the wiring upgrade as well...I haven't done the big 3/4 wiring yet, but will soon. I'm also running amp/subs/etc.
    Here is a link to someone that has done it, with detailed instructions and pics:
    https://www.tundras.com/threads/big-3-4-wire-upgrade.10285/
    Saltyhero13 likes this.
  3. Mar 31, 2023 at 8:22 AM
    JG1982
    Jeff
    Do you have an AGM battery? What alternator are you using?
  4. Mar 31, 2023 at 8:27 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
  5. Mar 31, 2023 at 8:30 AM
    JG1982
    Jeff
    Awesome, thanks! Last question, did you add in the diode fuse or does the H/O alternator properly charge the battery?
  6. Mar 31, 2023 at 8:32 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I added the diode fuse, but that was before I upgraded the alternator.
  7. Mar 31, 2023 at 8:34 AM
    JG1982
    Jeff
    Ok I lied, one more question. Did you use the GM diode or something else?
  8. Mar 31, 2023 at 8:51 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
