Changing transmission fluid
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Tmoody, Nov 10, 2022.
  1. Nov 10, 2022 at 11:26 AM
    Tmoody
    Tmoody [OP] New Member
    2017 tundra SR5
    None
    I have 75,000 miles on my 2017 tundra. Should I have the transmission fluid change now?
  2. Nov 10, 2022 at 11:28 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Definitely. Research how to do it properly. Change xfer case fluid (if 4wd) and diffs as well.
    JLS in WA likes this.
  3. Nov 10, 2022 at 11:29 AM
    AZBoatHauler
    So.Arizona
    Assuming you’ll be keeping the truck, sure. I started doing drain and fills at 45k. At this point if I was you, I’d consider doing a 100% replacement at the cooler then doing drain and fills every 25k or so.
  4. Nov 10, 2022 at 12:14 PM
    Tmoody
    2017 tundra SR5
    None
    Okay. Thanks for the reply
  5. Nov 10, 2022 at 12:42 PM
    CTundraForMe
    CTundraForMe New Member
  6. Dec 6, 2022 at 5:37 PM
    Campoj2
    Campoj2 New Member
    2019 Platinum
    None
    I am researching on how to do it right and I have a bunch of good videos on YT
  7. Dec 6, 2022 at 5:59 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Youtube - The Car Care Nut's recommendations. Great channel.
    Oil & Filter: 5k miles or 6mo. (Amsoil, personal preference)
    Transmission Fluid: 60k or 6yrs. (OME)
    Coolant: 50k or 5yrs. (OME)
    Differential & Transfer Case: 30k (OME or Aftermarket)
    Power Steering Fluid (Aftermarket Fluid)
    Sparks Plugs: 120k (OME)
    chugs and JLS in WA like this.
  8. Oct 12, 2024 at 3:25 PM
    jamesm
    jamesm New Member
    James
    2021 Tundra Sport Premium
    Hey, I use Amsoil for everything too...I have a 21 Tundra..62 000 KM...gonna change the tranny fluid...dealership says can't fo an exchange or flush cuz there's no hook ups for their machine...I'm going to do a drain and fill...should I bother dropping the pan...bolts look good on the pan but I've heard conflicting opinions...I live in Ontario (rust belt) but I do grease and oil spray truck every year...thoughts?
    Tripleconpanna likes this.
  9. Oct 12, 2024 at 6:32 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I would NOT drop the pan. The pan gives you access to what people call the 'filter' (and some of the electronics), but it's more of a 'screen' and doesn't need to be changed out like a traditional filter would... Drain and fill, leave the pan in place, and you're good to go :thumbsup:
    Regarding the bolts... Most folks say snap at least a couple removing the pan (even on trucks that don't have rust), but they are generally older than yours. I don't think you'd be doing yourself any favors by removing them 'just to keep them from seizing up'; I think you're better off to only touch them if you really need to get in there and just expect a few are going to go when you do...
    jamesm[QUOTED] likes this.
  10. Oct 12, 2024 at 6:37 PM
    Retired...finally
    Shortly after buying my 21 new I removed each pan bolt one at a time and applied anti seize to the bolt threads. Be careful not to over tighten the bolts after using a thread lube.
  11. Oct 12, 2024 at 6:44 PM
    Tripleconpanna
    My fear is that since most of these '21s (mine included) were built when the factories and 'ports' were having problems w/keeping skilled laborers on hand; it is likely many of these types of fasteners were done in a sloppy manner or crossed-threaded, etc... I'm guessing the liklihood of snapping a bolt or two that wasn't installed correctly in the first place is fairly high for our rigs that were built during this period. :notsure:
    jamesm likes this.
