Changing out every 3k instead of 5k??
Discussion in '2.5 Gen Tundras (2014-2021)' started by kevine0001, Mar 5, 2020.
  1. Mar 5, 2020 at 11:39 AM
    kevine0001
    kevine0001 [OP] New Member
    Kevin
    My tundra is not my daily driver. it probably gets less than 7500k per year. I usually change right before hunting season (August) and then again in Spring. Any reason to change it more frequently, just so oil isn't just sitting in the truck for 6+ months?
    ColoradoTJ likes this.
  2. Mar 5, 2020 at 11:43 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    No. Synthetic oil doesn’t break down over time like Dino oil.
  3. Mar 5, 2020 at 11:45 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Maybe do it annually
  4. Mar 5, 2020 at 11:48 AM
    kevine0001
    Kevin
    Well, I'm not going to let it go more than 5k, but good point on the syn versus conventional oil.
  5. Mar 5, 2020 at 12:30 PM
    Suprafantx
    Suprafantx New Member
    2020 4X4 White Tundra TSS
    3K, you are kidding! The day we have to change out the motor oil every 3K is over. I used to change out the oil every 2.5K-3K but it was long time ago. If I am in your case, I am going to use Mobil1 extended synthetic oil which is good for 15K and do the oil change every 10K or 1 year. I have other vehicles using ultimate full synthetic and do oil change every 17.5K.
  6. Mar 5, 2020 at 12:38 PM
    kevine0001
    Kevin
    yeah, even with synthetic, it's hard for me to let it go past 5k. but i appreciate the input
  7. Mar 5, 2020 at 2:20 PM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    Since I drive short trips daily (<5 miles) to work, I'll give Toyota's recommendation a shot to change the oil every 5k. The only real way to know what's best for your engine in your conditions is through oil analysis, but I think a fresh fill before it sits for a while is a good idea.
    Other suggestions in here were annual intervals or the Mobil 1 long life oil. I bet those two options together would be great, the extra additive pack in the long life oil would help keep the engine clean on the annual interval.
    Inquiringone likes this.
  8. Mar 5, 2020 at 2:27 PM
    kevine0001
    Kevin
    yeah, i already use the M1. but i usually change every 5k right now. i'll probably just stick with that. oil is usually dirty enough by that point
  9. Mar 10, 2020 at 9:25 AM
    Burdturger
    Burdturger New Member
    For those that change your own oil at 5k, does it even look dirty? I'm surprised that 5k is the recommended interval. First time I changed the Tacoma at 5k the oil looked brand new
  10. Mar 10, 2020 at 9:43 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I agree I change every 10. Castrol syn in now and at 7k it is still golden on dipstick. I have 57k on the odo. I think 5 is waste of money and time with synthetic oils
  11. Mar 10, 2020 at 9:46 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    ^^x2, same here i change mine every 10k.
    Hostage81 likes this.
  12. Mar 10, 2020 at 9:56 AM
    LlamaResistance
    LlamaResistance Member
    Concord, CA
    2017 White Crewmax SR5 TRD Offroad
    MLED Retrofitted Platinum Headlights, Ranch Hand bumper, Firestone airsprings, Leer 100XR Shell, Amp Research Steps
    The big change since before is we have much better fuel control these days so the problem of dilution of the oil by unburnt fuel is far reduced. Better combustion control leaves less soot to be washed into the oil. 10k oil changes are just fine even for the rarely driven. I've done oil analysis on these and the oil coming out is in good shape with some en-trained soot particulate making for the dark color.
    JohnLakeman likes this.
  13. Mar 10, 2020 at 10:00 AM
    Hostage81
    Hostage81 New Member
    SMJ
    Planet Earth
    2021 Trd Off Road
    Stock
    It would be interesting to see how often the owners with high mileage changed theirs.
  14. Mar 10, 2020 at 10:12 AM
    Burdturger
    i assume that our trucks leave the factory with oem toyota oil. is it not synthetic? just wondering why the recommended interval is 5k. Seems very short compared to other modern vehicles.
  15. Mar 10, 2020 at 10:24 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Actually non FFVs are 10k. The FFVs are 5 but I have no problem changing mine at 10.
    Ely010606 likes this.
  16. Mar 10, 2020 at 11:03 AM
    TheBeast The Beach
    Kirkland fully synthetic oil here :) so far so good. $25 for 10QT
    Burdturger and mceagle555 like this.
  17. Mar 10, 2020 at 11:23 AM
    1FSTREX
    1FSTREX New Member
    Will
    Northern California
    2023 Limited OR
    Personally, I still change my oil every 3-4k. I understand that our trucks and most oils are rated to go much much longer than that. But my thought process still stands that oil breaks down no matter what. I daily drive my truck, tow quite a bit, and many times through mountains. I plan to keep my truck forever and rather invest the money now to ensure my truck can last for 250k plus.
    Tundra_361 likes this.
  18. Mar 10, 2020 at 12:08 PM
    kevine0001
    Kevin
    I stick with every 5k. Even with synthetic. I've done some oil changes when it the draining oil doesn't look too bad, like dark honey. A couple times it was darker. I live in Santa Clarita, CA, where between May and Sept/Oct, it gets past 100 degrees outside. Even though I don't daily drive my truck, I drive it enough and like 1FSTREX said, it's an investment to hopefully have my truck last well beyond 200k miles.
    15whtrd likes this.
  19. Mar 10, 2020 at 2:50 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Exactly...Since like 1954. :facepalm:
    You might be suffering from denialism.
    Inability to accept reality (Denialism): In the psychology of human behavior, denialism is a person's choice to deny reality as a way to avoid a psychologically uncomfortable truth. Denialism is an essentially irrational action that withholds the validation of a historical experience or event, when a person refuses to accept an empirically verifiable reality.
    Run your present oil for one year (your truck WILL NOT self-distruct). Then do an annual change, regardless of mileage, up to 10K miles. Catch a drained oil sample. Buy a pre-paid Blackstone oil analysis kit to confirm reality for yourself. Send the sample off for analysis. Read the report. With that revelation, you can continue being in denial, or you can do annual oil changes and save big bucks on one 8.5 quart oil change every year. Experts will tell you there is no correlation between color of used oil and condition of used oil.
  20. Mar 10, 2020 at 3:53 PM
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    Do you guys that do extended oil changes change the filter in between or do you use the same filter for 10k plus miles?
  21. Mar 10, 2020 at 4:05 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    I usually use NAPA filters, and use the ones rated for extended OCI. Platinum I think?
  22. Mar 10, 2020 at 4:08 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    L O F @ 5k full synthetic Mobile 1,
  23. Mar 11, 2020 at 5:00 AM
    Suprafantx
    I use the same oil filter for 17.5 K and always use Toyota oil filter.
  24. Mar 11, 2020 at 5:56 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    oil threads are interesting to me. I remember reading in my 1984 Toyota truck manual, oil change interval was 7500 miles.
  25. Mar 11, 2020 at 6:06 AM
    I’m sure you would have mentioned it, but are you supercharged? I would change more frequently if you do (3-4K).
    Like others have said, full synthetic oils don't break down like conventional oils do. 5k is the lowest amount of miles I would change at.
  26. Mar 11, 2020 at 7:20 AM
    RickC
    Rick
    Knoxville TN
    Depending on driving and use, I don't think I could ever go that long. The most I have seen is 15k miles on oil and I have never seen an oil filter recommended at that interval. Have you ever had the oil analyzed or filter analyzed after an oil change?
  27. Mar 11, 2020 at 7:46 AM
    Cavalrysr5
    Cavalrysr5 New Member
    Jared
    2020 tundra cavalry blue sr5
    I plan on changing mine every 5k, I can do it for roughly 55 bucks with mobil 1. Cheap insurance and I can see what is going on with it early if needed.
    Also considering it will be every 9 months or so. Plus with my wife driving it, it only gets 7 miles on it a day for 183 days a year plus whatever out of town trips we take we might take it instead of the corolla.
    My corolla hybrid I will do at 7.5K.
  28. Mar 11, 2020 at 9:03 AM
    Suprafantx
    Honda recommends oil filter change every 20K on some models. I don't have to send the oil for analysis because I replace oil earlier than I should. The oil change recommendation for Mobil1 ultimate synthetic oil is 20K and I did change at 17.5K. I learned that I did many unnecessary oil changes when I was younger. Oil filter will work better when it is aging (I am not talking when the filter is more than 30K) but I still replace the filter every oil change. The fact is I never have a single problem with the engines of all my vehicles (Toyota and Lexus) and I usually keep them up to 240K. Many other things will fall apart before the engines do.
  29. Mar 11, 2020 at 10:30 AM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    nevertheless, it's worth it. doesn't matter if you change at 1k or 20k. oil tests can show if you have certain internal parts wearing out quicker than expected and can predict if something is going to fail way before it actually does. it's nice to have a pattern of typical metallic content, so if one (or more) increases as the mileage goes up, you could catch something before it grenades the engine. our 3UR's are pretty bulletproof, but nothing is ever built perfectly.
    TRDSPORT118 and JLS in WA like this.
  30. Mar 11, 2020 at 12:04 PM
    BecauseRacecar
    Ohio
    The recommended interval is only 5k in 2019+ models when you meet certain conditions (e.g. frequent towing, frequent trips below 5 miles distance, etc)
